The Solaris LDAP naming service allows one or more attribute names to be remapped for any of its services. (The Solaris LDAP client uses the well-known attributes documented in Chapter 18, General Reference.) If you map an attribute, you must be sure that the attribute has the same meaning and syntax as the original attribute. Note that mapping the userPassword attribute may cause problems.
There are a couple of reasons you might want to use schema mappings.
You want to map attributes in an existing directory server
If you have user names that differ only in case, you must map the uid attribute, which ignores case, to an attribute that does not ignore case
The format is service:attribute-name=mapped-attribute-name.
If you wish to map more than one attribute for a given service, you can define multiple attributeMap attributes.
In the following example, the employeeName and home attributes would be used whenever the uid and homeDirectory attributes would be for the passwd service.
attributeMap: passwd:uid=employeeName attributeMap: passwd:homeDirectory=home |
There exists one special case where you can map the passwd service's gecos attribute to several attributes. The following is an example.
attributemap: gecos=cn sn title |
The above maps the gecos values to a space-separated list of the cn, sn and title attribute values.
