LDAP naming service clients authenticate to the LDAP server according to a credential level. LDAP clients can be assigned three possible credential levels with which to authenticate to a directory server.
anonymous
proxy
proxy anonymous
Anonymous
If you use anonymous access, you only have access to data that is available to everyone. Also, you should consider the security implications. Allowing anonymous access for certain parts of the directory implies that anyone with access to the directory will be able to perform those operations. If you are using an anonymous credential level, you will need to allow read access to all the LDAP naming entries and attributes.
Allowing anonymous write to a directory should never be done, as anyone could change information in the DIT to which they have write access, including another user's password, or their own identity.
The iPlanet Directory Server 5.1 allows you to restrict access based on IP addresses, DNS name, authentication method and time-of-day. You might want to limit access with further restrictions. See “Managing Access Control” in the iPlanet Directory Server 5.1 Administrator's Guide for more information.
Proxy
The client authenticates or binds to the directory using a proxy account. This proxy account can be any entry that is allowed to bind to the directory. This proxy account needs sufficient access to perform the naming service functions on the LDAP server. You will need to configure the proxyDN and proxyPassword on every client using the proxy credential level. The encrypted proxyPassword will be stored locally on the client. You can setup different proxies for different groups of clients. For example, you can configure a proxy for all the sales clients to access both the company-wide-accessible and sales directories and directories, while preventing sales clients from accessing human resource directories with payroll information. Or, in the most extreme cases, you can either assign different proxies to each client or assign just one proxy to all clients. A typical LDAP deployment would probably lie between the two extremes. Consider the choices carefully. Too few proxy agents might limit the your ability to control user access to resources. However, having too many proxies complicates the setup and maintenance of the system. You need to grant the appropriate rights to the proxy user. This will vary depending on your environment. See the following section for information on how to determine which authentication method makes the most sense for your configuration.
If the password changes for a proxy user, you will need to update it on every client that uses that proxy user. If you use password aging on LDAP accounts, be sure to turn it off for proxy users.
Be aware that the proxy credential level applies to all users and processes on any given machine. If two users need to use different naming policies, they must use different machines.
In addition, if clients are using a proxy credential to authenticate, the proxyDN must have the same proxyPassword on all of the servers.
proxy anonymous
proxy anonymous is a multi-valued entry, in that more than one credential level is defined. A client assigned the proxy anonymous level will first attempt to authenticate with its proxy identity. If the client is unable to authenticate as the proxy user for whatever reason (user lock out, password expired, for example), then the client will use anonymous access. This might lead to a different level of service, depending on how the directory is configured.
If you configure a client to use a proxy identity, the client saves its proxyDN and proxyPassword in /var/ldap/ldap_client_cred. For the sake of increased security, this file is restricted to root-access only and the value of proxyPassword is encrypted. While past LDAP implementations have stored proxy credentials in a client's profile, the Solaris 9 LDAP does not. Any proxy credentials set using ldapclient during initialization are stored locally. This results in improved security surrounding a proxy's DN and password information. See Chapter 16, Client Setup (Task) for more information on setting up client profiles.
