System Administration Guide: Naming and Directory Services (DNS, NIS, and LDAP)
Choosing Authentication Methods
When you assign the proxy or proxy-anonymous credential level to a client, you also need to select a method by which the proxy authenticates to the directory server. By default, the authentication method is none which implies anonymous access. The authentication method may also have a transport security option associated with it.
The authentication method, like the credential level, may be multi-valued. For example, in the client profile you could specify that the client first tries to bind using the simple method secured by TLS. If unsuccessful, the client would try to bind with the sasl/digest-MD5 method. The authenticationMethod would then be tls:simple;sasl/digest-MD5.
The LDAP naming service supports some Simple Authentication and Security Layer (SASL) mechanisms. These mechanisms allow for a secure password exchange without requiring TLS. However, these mechanisms do not provide data integrity or privacy. See RFC 2222 for information on SASL.
The following authentication mechanisms are supported.
Caution – Caution –
iPlanet Directory Server 5.1 requires passwords to be stored in the clear in order to use digest-MD5. If the authentication method is set to sasl/digest-MD5 or tls:sasl/digest-MD5, then the passwords for the proxy user will need to be stored in the clear. Be careful that the userPassword attribute has the proper ACIs if it is stored in the clear, so that it is not readable.
Authentication and Services
The authentication method can be specified for a given service in the serviceAuthenticationMethod attribute. The following services currently support this.
Note –
If the service does not have a serviceAuthenticationMethod set, it will default to the value of the authenticationMethod attribute.
The following example shows a section of a client profile in which the users will use sasl/digest-MD5 to authenticate to the directory server, but will use an SSL session to change their password.
serviceAuthenticationMethod=pam_ldap:sasl/digest-MD5
serviceAuthenticationMethod=passwd-cmd:tls:simple
