System Administration Guide: Security Services
in_addr Token
The in_addr token contains a 4-byte Internet Protocol address. The in_addr token has two fields:
The praudit command displays the in_addr token as follows:
ip address,129.150.113.7
For the Solaris 8 release, the Internet address can be displayed as an IPv4 address that uses 4 bytes, or as an IPv6 address that uses 16 bytes to describe the type, and 16 bytes to describe the address.The following figure shows the format of an in_addr token.
Figure 25–14 in_addr Token Format
The preceding context describes the graphic.
