System Administration Guide: Security Services
ip Token
The ip token contains a copy of an Internet Protocol header but does not include any IP options. The IP options can be added by including more of the IP header in the token. The ip token has two fields:
The praudit command displays the ip token as follows:
ip address,0.0.0.0
The IP header structure is defined in the /usr/include/netinet/ip.h file. The following figure shows the format of an ip token.
Figure 25–15 ip Token Format
The preceding context describes the graphic.
