An audit_control file on each machine is read by the audit daemon (see the audit_control(4) man page). The audit_control file is located in the /etc/security directory. Each machine has its own local audit_control file so that every machine can mount their audit file systems from different locations or in a different order. For example, the primary audit file system for machineA might be the secondary audit file system for machineB.
You specify four kinds of information in the audit_control file:
The audit flags line (flags:) contains the audit flags that preselect which classes of events are audited for all users on the machine. The audit flags specified here are referred to as the machine-wide audit flags or the machine-wide audit preselection mask. Audit flags are separated by commas, with no spaces.
The nonattributable flags line (naflags:) contains the audit flags that preselect which classes of events are audited when an action cannot be attributed to a specific user. The flags are separated by commas, with no spaces.
The audit threshold line (minfree:) defines the minimum free-space level for all audit file systems. The minfree percentage must be greater than or equal to 0. The default is 20 percent.
The directory definition lines (dir:) define which audit file systems and directories the machine will use to store its audit log files. You can define one or more directory definition lines. The order of the dir: lines is significant. The auditd daemon creates audit files in the directories in the specified order (see the audit(1M) man page). The first directory is the primary audit directory for the machine. The second directory is the secondary audit directory where the audit daemon creates audit trail files when the first directory becomes full, and so forth.
You create an audit_control file during the configuration process on each machine.
When you make changes to the audit_control file, you then run the audit -s to instruct the audit daemon to reread the file.
The audit -scommand does not change the preselection mask for existing processes. Use auditconfig, setaudit (see the getuid(2) man page), or auditon for existing processes.
The following is a sample audit_control file for the machine dopey. dopey uses two audit file systems on the audit server blinken, and a third audit file system that is mounted from the second audit server winken. The third file system is used only when the audit file systems on blinken become full or unavailable. The minfree value of 20 percent specifies that the warning script is run when the file systems are 80 percent filled and the audit data for the current machine will be stored in the next available audit directory, if any (see the audit_warn(1M) man page). The flags specify that all logins and administrative operations are to be audited (whether or not they succeed), and that failures of all types, except failures to create a file system object, are to be audited.
flags:lo,ad,-all,^-fc naflags:lo,nt minfree:20 dir:/etc/security/audit/blinken/files dir:/etc/security/audit/blinken.1/files # # Audit filesystem used when blinken fills up # dir:/etc/security/audit/winken |
