System Administration Guide: Security Services
The audit_data File
When the auditd daemon starts on each machine, it creates the file /etc/security/audit_data. The format of the file consists of a single entry with the two fields separated by a colon (see the audit_data(4) man page). The first field is the audit daemon's process ID. The second field is the path name of the audit file to which the audit daemon is currently writing audit records. Here is an example:
# cat /etc/security/audit_data
116:/etc/security/audit/blinken.1/files/19990320100002.not_terminated.dopey
