Whenever the audit daemon encounters an unusual condition while writing audit records, it invokes the /etc/security/audit_warn script. See the audit_warn(1M) man page. You can customize this script for your site to warn of conditions that might require manual intervention, or you could specify how to handle them automatically. For all error conditions, audit_warn writes a message to the console and sends a message to the audit_warn mail alias. You should set up this alias when you enable auditing.
When audit daemon detects the following conditions, it invokes the audit_warn script.
An audit directory has become more full than the minfree value allows. The minfree value or soft limit is a percentage of the space available on an audit file system.
The audit_warn script is invoked with the string soft and the name of the directory whose available space has gone below the minimum value. The audit daemon switches automatically to the next suitable directory and writes the audit files there until this new directory reaches its minfree limit. The audit daemon then goes to each remaining directory in the order that is listed in the audit_control file, and writes audit records until each directory is at its minfree limit.
All the audit directories have reached the minfree threshold.
The audit_warn script is invoked with the string allsoft. A message is written to the console and mail is sent to the audit_warn alias.
When all audit directories that are listed in the audit_control file have reached their minfree threshold, the audit daemon switches back to the first directory, and writes audit records until the directory becomes completely full.
An audit directory has become completely full with no space remaining.
The audit_warn script is invoked with the string hard and the name of the directory. A message is written to the console and mail is sent to the audit_warn alias.
The audit daemon switches automatically to the next suitable directory with any space available, if any. The audit daemon goes to each remaining directory in the order that is listed in the audit_control file, and writes audit records until each directory is full.
All the audit directories are completely full. The audit_warn script is invoked with the string allhard as an argument.
In the default configuration, a message is written to the console and mail is sent to the audit_warn alias. The processes that generate audit records are suspended. The audit daemon goes into a loop, waiting for space to become available, and resumes processing audit records when that happens. While audit records are not being processed, no auditable activities occur. Every process that attempts to generate an audit record is suspended. For this reason, you should set up a separate audit administration account that could operate without any auditing enabled. Then, you could continue operations without being suspended.
An internal error occurs, such as:
Another audit daemon process is already running (string ebusy)
A temporary file cannot be used (string tmpfile)
The auditsvc() system call fails (string auditsvc)
A signal was received during auditing shutdown (string postsigterm)
Mail is sent to the audit_warn alias.
A problem is discovered with the syntax of the audit_control file. By default, mail is sent to the audit_warn alias and a message is sent to the console.
