The following list summarizes what the audit daemon, auditd, does.
auditd opens and closes audit log files in the directories that are specified in the audit_control file, in the order in which they are specified.
auditd reads audit data from the kernel and writes it to an audit log file.
auditd executes the audit_warn script when the audit directories fill past limits that are specified in the audit_control file. The script, by default, sends warnings to the audit_warn mail alias and to the console.
By default, when all audit directories are full, processes that generate audit records are suspended. In addition, the auditd command writes a message to the console and to the audit_warn mail alias. The audit policy can be reconfigured with the auditconfig. At this point, only the system administrator can log in to write audit files to tape, delete audit files from the system, or do other cleanup.
The auditd daemon can be started automatically when the machine is brought up to multiuser mode, or you can start it from the command line. When the audit daemon is started, it determines the amount of free space necessary for audit log files.
The daemon uses the list of audit directories in the audit_control file as possible locations for creating audit files. The audit daemon maintains a pointer into this list of directories, starting with the first directory. Every time the audit daemon needs to create an audit file, it puts the file into the first available directory in the list, starting at the audit daemon's current pointer. You can reset the pointer to the beginning of the list by running the audit -s command. When you use the audit -n command to instruct the daemon to switch to a new audit file, the new file is created in the same directory as the current file.
