The /etc/system file contains commands that the kernel reads during initialization to customize the system operations. The bsmconv and bsmunconv shell scripts, which are used to activate and deactivate auditing, modify the /etc/system file. The bsmconv shell script adds the following lines to the /etc/system file:
set c2audit:audit_load=1 set abort_enable=0 |
The first command causes the c2audit loadable kernel module (auditing module) to be loaded when the system is booted. The second command disables the use of the Stop-A keyboard sequence. The Stop-A keyboard sequence halts the system and can invoke a debugger, which could be a security breach. The bsmunconv shell script removes these lines, which results in auditing being disabled when the system is rebooted.
