Device allocation satisfies part of the object-reuse requirement. The device-clean scripts make sure that data that is left on a device by one user is cleared before the device is allocatable by another user.
The st_clean device-clean script supports three tape devices. The supported tape devices are:
SCSI 1/4-inch tape
Archive 1/4-inch tape
Open-reel 1/2-inch tape
The st_clean script uses the rewoffl option to the mt command to affect the device cleanup. For more information, see the mt(1) man page. If the script runs during system boot, it queries the device to see if the device is online and has media in it. The 1/4-inch tape devices that have media in them, are placed in the allocate error state to force the administrator to clean up the device manually.
During normal system operation, when the allocate or deallocate command is executed in interactive mode, the user is prompted to remove the media from the device that is being deallocated. The script pauses until the media is removed from the device.
The following table shows the device-clean scripts for diskettes and CD-ROM devices.
Table 25–9 Device-Clean Scripts for Diskettes and CD-ROM Devices|
Disk Device Type |
Device-Clean Script |
Diskette | |
CD-ROM |
The scripts use the eject command to remove the media from the drive. See the eject(1) man page. If the eject command fails, the device is placed in the allocate error state.
Audio devices are cleaned up with an audio-clean script. The script performs an AUDIO_DRAIN ioctl system call to flush the device, then an AUDIO_SETINFO ioctl system call command to reset the device configuration to default. In addition, the script retrieves the audio chip registers by using the AUDIOGETREG ioctl system call. Any registers that deviate from the default settings are reset by using the AUDIOSETREG ioctl system call.
