If you add more allocatable devices to the system, you might need to create your own device-clean scripts. The deallocate command passes a parameter to the device-clean scripts. The parameter, shown here, is a string that contains the device name (see the device_allocate(4) man page):
st_clean -[I|F|S] device-name |
Device-clean scripts must return “0” for success and greater than “0” for failure. The options -I, -F, and -S help the script determine its running mode.
The -I option is needed during system boot only. All output must go to the system console. Failure or inability to forcibly eject the media must put the device in the allocate error state.
The -F option is for forced cleanup. This option is interactive and assumes that the user is available to respond to prompts. A script with this option must attempt to complete the cleanup if one part of the cleanup fails.
The -S option is for standard cleanup. This option is interactive and assumes that the user is available to respond to prompts.
