All authorizations are stored in the auth_attr database. Authorizations can be assigned directly to users (or roles) in the user_attr database. Authorizations can also be assigned to rights profiles, which are assigned to users.
The fields in the auth_attr database are separated by colons, as follows:
authname:res1:res2:short_desc:long_desc:attr |
The following table describes these fields.
Field Name |
Description |
authname |
A unique character string that is used to identify the authorization in the format prefix.[suffix]. Authorizations for the Solaris operating environment use solaris as a prefix. All other authorizations should use a prefix that begins with the reverse-order Internet domain name of the organization that creates the authorization (for example, com.xyzcompany). The suffix indicates what is being authorized, which is typically the functional area and operation. When the authname consists of a prefix and functional area and ends with a period, the authname serves as a heading to be used by applications in their GUIs, rather than as an actual authorization. The authname of solaris.printmgr. is an example of a heading. When authname ends with the word “grant,” the authname serves as a grant authorization and lets the user delegate authorizations with the same prefix and functional area to other users. The authname of solaris.printmgr.grant is an example of a grant authorization. solaris.printmgr.grant gives the user the right to delegate such authorizations as solaris.printmgr.admin and solaris.printmgr.nobanner to other users. |
res1 |
Reserved for future use. |
res2 |
short_desc |
A terse name for the authorization that is suitable for display in user interfaces, such as in a scrolling list in a GUI. |
long_desc |
A long description. This field identifies the purpose of the authorization, the applications in which it is used, and the type of user who might be interested in using it. The long description can be displayed in the help text of an application. |
attr |
An optional list of semicolon-separated (;) key-value pairs that describe the attributes of an authorization. Zero or more keys can be specified. The keyword help identifies a help file in HTML. Help files can be accessed from the index.html file in the /usr/lib/help/auths/locale/C directory. |
The following example shows an auth_attr database with some typical values.
% grep printer /etc/security/auth_attr solaris.admin.printer.:::Printer Information::help=AuthPrinterHeader.html solaris.admin.printer.delete:::Delete Printer Information::help=AuthPrinterDelete.html solaris.admin.printer.modify:::Update Printer Information::help=AuthPrinterModify.html solaris.admin.printer.read:::View Printer Information::help=AuthPrinterRead.html |
Note that solaris.admin.printer. is defined to be a heading, because it ends in a dot (.). Headings are used by the GUIs to organize families of authorizations.
