The prof_attr database stores the name, description, help file location, and authorizations that are assigned to rights profiles. The commands and security attributes that are assigned to rights profiles are stored in the exec_attr database (see The exec_attr Database). The fields in the prof_attr database are separated by colons:
profname:res1:res2:desc:attr |
The following table describes these fields.
Field Name |
Description |
profname |
The name of the rights profile. Rights profile names are case-sensitive. This name is also used by the user_attr database to indicate rights profiles that are assigned to roles and users. |
res1 |
Reserved for future use. |
res2 |
desc |
A long description. This field should explain the purpose of the rights profile, including what type of user would be interested in using it. The long description should be suitable for display in the help text of an application. |
attr |
An optional list of key-value pairs that are separated by semicolons (;) that describes the security attributes to apply to the object on execution. Zero or more keys can be specified. The two valid keys are help and auths. The keyword help identifies a help file in HTML. Help files can be accessed from the index.html file in the /usr/lib/help/auths/locale/C directory. The keyword auths specifies a comma-separated list of authorization names that are chosen from those names that are defined in the auth_attr database. Authorization names can be specified with the asterisk (*) character as a wildcard. |
The following example shows a typical prof_attr database. Note that the Printer Management rights profile is a supplementary rights profile that is assigned to the Operator rights profile.
% grep 'Printer Management' /etc/security/prof_attr Printer Management:::Manage printers, daemons, spooling:help=RtPrntAdmin.html; \ auths=solaris.admin.printer.read,solaris.admin.printer.modify,solaris.admin.printer.delete \ Operator:::Can perform simple administrative tasks:profiles=Printer Management,\ Media Backup,All;help=RtOperator.html ... |
