BounceKeys aids people who have trouble holding down a key, or who tend to hit a key repeatedly when they mean to press it only once. BounceKeys sets the window system to ignore rapid, repeated pressings of a single key.
Both SlowKeys and BounceKeys cannot be active at once.
To turn BounceKeys on and off, check the BounceKeys check box on the AccessX main window.
The Debounce Time is the interval that must pass before a second pressing of a key is accepted.
You can set this interval with the “Debounce time (sec)” slider. (See Figure E–4.) This delay can range from zero to five seconds.
