Solaris Common Desktop Environment: User's Guide
SlowKeys Settings
Setting the Notification Style
You may want to be notified of a key's status while SlowKeys is active. That way you don't have to guess whether you've held the key down long enough for it to be accepted.
There are two check boxes (“pressed” and “accepted”) in the Settings window for setting how you want to be notified of a key's status when SlowKeys is in effect. By checking these boxes, you can have your machine beep:
Setting the Acceptance Delay
The acceptance delay is the interval between when you first press a key and when it transmits input. You can set this with the “Acceptance delay (sec” slider located in the Settings window. (See Figure E–4.) This delay can range from zero to five seconds.
