Video is the Java Media Player application used for viewing or saving video data in several formats. The Java Media Player is automatically launched once you select the Audio/Video menu option from the Applications menu. This is the default unless you select the Audio option to customize your environment.
Audio is a CDE Motif application for playing, recording, or saving audio data in AU (Sun), WAV (PC), or AIFF (Macintosh) format.
Use the Java Media Player for viewing multimedia files. The Java Media Framework (JMF) is an application programming interface (API) for incorporating media data types into Java applications and applets. It is specifically designed to take advantage of Java platform features.
All video functions start with the main window.
You can open a video file by choosing Open file from the File menu. Once you open a file, the main window alters to display the file and a control panel at the bottom of the screen.
The control panel consists of the following icons and their respective functions:
Click this button to begin playing a file.
Click this button to pause a file.
This button indicates how far a file has played.
Click this button to alternatively turn on or turn off the sound.
Click this button to increase or decrease the volume.
Click this button to view information on a file.
The Java Media Player supports the following formats:
8 bits mono/stereo linear
16 bits mono/stereo linear
G.711 mono
IMA4 ADPCM
Audio:
G.711 mono
GSM mono
Video
Cinepak
Indeo (iv31 and iv32)
JPEG (411, 422, 111)
GSM mono audio
Type 1 & 2 MIDI audio files
This format is not available on Solaris x86.
Video: MPEG-1
Audio: MPEG-1, Layer 1 and 2
MPEG layer 1 or 2 audio
Audio:
G.711 mono
GSM mono
IMA4 ADPCM
u-law
Video:
Cinepak
H.261
H.263
Raw
RLE
SMC
Headspaces Rich Media Format audio files.
Audio:
4 bits mono DVI 8 kHz
4 bits mono DVI 11.05 kHz
4 bits mono DVI 22.05 kHz
4 bits mono DVI 44.1 kHz
G.711 mono
GSM mono
G.723 mono
Video:
H.261
H.263
G.711 mono
Video: H.263
G.711 mono
GSM mono
DVI ADPCM (not MSADPCM)
The following tasks can be performed on multimedia files using JMF.
From the File menu, select New player.
From the File menu, select Exit.
The Java Media Player server shuts down 15 seconds after the last player exits.
From the File menu, select Open file.
From the File menu, select Close player.
This will close the file but will not exit the Java Media Player.
From the File menu, select Open URL.
Enter the path or folder name in the text field.
From the Files window, double click the file that you want to open.
Click on the triangle at the bottom left of the screen.
Click and drag the slider to your left.
The file will begin playing from the point you placed the slider.
Click and drag the slider to your right.
You can either adjust or mute the volume for a file. To adjust the volume of a file:
Click on the triangles at the bottom right of the screen.
A progress bar will indicate the change in volume.
To select mute for a file:
Click on the speaker icon at the bottom right of the screen.
The icon will change to indicate that the file is in mute mode.
Place the cursor over the triangle on the lower left of the screen.
Right-click the mouse button.
From the pull-down menu select one of the options.
1/10 speed - 1/10th the original rate
Half speed - 1/2 the original rate
Normal speed - the original rate
Double speed - twice the original rate
Triple speed - three times the original rate
Quadruple speed - four times the original rate
Place the cursor over the screen.
From the pull-down menu select a zoom option:
Half Size - Shrinks the screen to half its original size
Normal - Alters the screen to accommodate the picture
Double Size - Expands the screen to twice its original size
Quadruple Size - Adjusts the screen to 4 times its original size
Click on the “i” icon on the bottom right of the screen.
A pop-up window displays details on the file you are viewing.
There are several ways to start Audio:
From the Front Panel
From the command line
From the Workspace Programs menu
Click the Voice Note control on the Applications subpanel to start the application.
Audio runs in note mode, and automatically starts recording.
Click the Stop button to stop recording.
You can start Audio and open files directly from the command line.
Or:
Type sdtaudio filename to start Audio and open a specific file.
Place the mouse pointer anywhere on the background of the desktop (the workspace) and click mouse button 3.
The Workspace menu appears.
Choose Programs, and then choose Audio from the Programs submenu.
The Audio main window is displayed.
Choose Exit from the File menu or Close from the Window menu, or hold down the Alt key and press the F4 key with the mouse cursor over the Audio main window to exit Audio.
All Audio functions start with the main window. Open an audio file by choosing Open from the File menu; record by choosing New from the File menu and clicking the Record Audio button; set startup, recording, or playing options by choosing the appropriate item from the Options menu.
In the same way as Text Note allows you to rapidly create small text files and display them on the desktop, Voice Note allows you to record an audio message and save it on the desktop for playing later. For example, you might want to record the pronunciation of a foreign name, or a useful quotation which you don't want to type.
The Voice Note control is located on the Applications subpanel of the Front Panel. When you click the Voice Note control it runs the Audio application, which immediately starts recording from your host's microphone. To stop recording, you click the Stop button or exit the Audio application.
The sound file that is created is displayed on your desktop when you exit the Audio application. You can remove it by choosing Remove From Workspace from the right-mouse button popup menu. You can remove it from your file system by deleting it from your home directory.
If you click the Voice Note control and neglect to stop Audio, it can record and save a huge file that may eventually use up all your disk space.
An audio file can be displayed with or without a waveform displayed. The waveform is a graphic depiction of the sound levels of an audio file.
To show the waveform window, click the Show Wave Window button.
To hide the waveform window, click the button again.
The button is a toggle, changing from Show Wave Window to Hide Wave Window and back again to Show Wave Window as it is clicked.
If stereo viewing is enabled, the window depicts levels and volume individually for left and right channels.
Choose Startup from the Options menu.
The Options dialog box is displayed, with Startup selected as the Category. If the Options dialog box is already displayed, choose Startup from the Category menu.
Click Waveform View Enabled or Stereo View Enabled.
Click OK.
The Options dialog box closes. The next time you start Audio the monaural or stereo waveform will be displayed. The Stereo View Enabled button is inactive if the current audio file is in monaural format.
You can open an audio file from the Audio File menu or by dragging and dropping it from File Manager onto Audio. Once you have opened an audio file or recorded something, you can play it from the beginning or from any point in the file. You can specify whether an audio file will be played automatically when it is opened.
Choose Open from the File menu or hold down the Control key and press ``o'' with the mouse cursor over the Audio main window.
The Audio-Open File dialog box is displayed.
Navigate to the folder where the audio file is located.
Navigate by selecting a folder in the Folders list or by entering a folder name in the Enter path or folder name text field.
Optional. Type an audio-file suffix (au, wav, aiff) after the asterisk (*) in the Filter field.
Only files with the specified suffix will be listed in the Files field.
Press Return or click Update to update the change in the folder location or filter field.
Select a file from the Files list.
Double-click the file in the Files list or select it and click OK.
The selected file is opened. If Automatically play audio file on Open is selected in the Options-Play dialog box, the audio file starts playing.
Audio automatically detects the type of device accessed. If Audio is started with a play-only device, only playback options and output sources are available. If audio is started with a record-only device, such as a microphone, only record options and input sources are available.
Open File Manager and navigate to the folder where the audio file is located.
Drag the audio file icon from File Manager and drop it on the Audio main window.
The Selected file is opened. If Automatically play audio file on Open is selected in the Options-Play dialog box, the audio file starts playing.
Choose Play from the Options menu.
The Options dialog box is displayed, with Play selected as the Category. If the Options dialog box is already displayed, choose Play from the Category menu.
Determine whether files should automatically play when they are opened.
Click Automatically play audio file on Open to automatically play files when they are opened.
Deselect Automatically play audio file on Open if you do not want files to automatically start playing when opened.
Move the Set Default Play Volume and Balance Audio Output sliders to desired positions.
Position the mouse pointer over the slider and press mouse button 1 as you move the mouse to change slider positions.
Click OK to apply the specified values and close the Options dialog box.
Once you have recorded something or opened an audio file, you can play it, as follows. You can play AU, WAV, or AIFF files.
Click the Play Audio button.
When you click Play Audio, play begins at the play pointer position. The file is played from the beginning if it has just been opened or if you have just created the recording. If you click the Stop Playing button during play and then click Play Audio, play begins at the previous stop point.
Note that the Play Audio button is a toggle: before play, it is Play Audio; during play, it is Stop Playing.
Optional. Move the play pointer to a new start play position.
To move the play pointer to the beginning of the file, click the Go to Start button.
To move the play pointer to the end of the file, click the Go to End button.
To move the play pointer to a position within the file:
If the waveform is not displayed, drag the slider with mouse button 1.
If the waveform is displayed, click anywhere in the waveform window.
Optional. Adjust the output volume by clicking on the Increase Volume or Decrease Volume buttons.
To mute the output, click the Turn Sound Off button.
To stop playing the file, click the Stop Playing button.
The Play buttons are inactive when no file has been loaded or recorded.
You can record and save audio files in three formats.
You can specify audio format, sample rate, encoding method, channels, record volume, and input balance in the Options dialog box. You can also specify whether you will specify the values when you start recording, or if the set values will be used automatically when recording or if you will specify the values when you start recording.
Choose Record from the Options menu.
The Options dialog box is displayed, with Record selected as the Category. If the Options dialog box is already displayed, choose Record from the Category menu.
Choose AU, WAV, or AIFF from the Audio Format menu.
AU, which is the default, is Sun audio format. WAV is Microsoft PC format. AIFF is Macintosh audio format.
Choose samples per second from the Sample Rate menu.
8.000kHz is the default. Other rates fall in a range between 5.510kHz and 48.000kHz.
Choose an encoding method from the Encoding menu.
Encoding method options include u-law, A-law, and linear PCM.
Choose Mono or Stereo from the Channels menu.
Choose Mono, the default, for single-track recording, or Stereo for multiple channels.
Determine whether to use the selected recording options as the default for new files.
To use the selected recording options as the default, click Use selected recording options as default for new files.
To specify recording options when you click Record Audio, click Ask me when I start recording.
Set default record volume and balance the audio input.
Position the mouse pointer over the slider and press mouse button 1 as you move the mouse to set the Default Record Volume and Balance Audio Input sliders to desired positions.
You can record Audio files from a microphone, line-in, or CD source.
Specify recording options.
Choose New from the File menu or hold down the Control key and press ``n'' with the mouse cursor over the Audio main window.
If a previous recording has not been saved, you are asked if you want to save it.
Prepare to record.
Be sure that the selected input device is connected to your computer and ready for transmission, and that the microphone or other input device is on.
Click Record Audio button and start recording.
Speak, sing, or play into the microphone or start transmission of audio from a line-in or CD source. Recording starts as soon as you click Record Audio unless you have specified Ask me when I start recording in the Options-Record dialog box.
When recording is complete, click the Stop Recording button.
Click Play Audio button to play what you have just recorded.
The Record Audio button, which becomes the Stop Recording button during recording, is inactive if a file is open; the button's function is not displayed in the current function area when it is inactive. Similarly, the Play and Go to buttons are inactive when no audio file has been opened or recorded.
You can save an existing audio file or a new recording in AU, AIFF, or WAV format.
Choose Save As from the File menu or hold down the Control key and press ``a'' with the mouse cursor over the Audio main window.
The Audio - Save As dialog box will be displayed.
Specify the folder in which you want to save the file.
Change to a different folder, if you wish. Press Return or click Update to update the folder location.
Choose a format (AU, WAV, or AIFF) from the Audio Format menu.
Type a name in the Enter file name field.
Audio files are usually named with .au, .wav, or .aiff suffixes for easy identification. To overwrite an existing file, select the file in the Files list.
Click OK to save the audio file or recording.
You can specify output (play) and input (record) devices for playing and recording. Audio automatically detects the type of device accessed. If Audio is started with a play-only device, only playback options and output sources are available. If Audio is started with a record-only device, such as a microphone, only record options and input sources are available.
Choose Devices from the Options menu.
The Options dialog box is displayed, with Devices selected as the Category. If the Options dialog box is already displayed, choose Devices from the Category menu.
Select Speaker, Headphone, or Line Out as Output Sources.
Note that you can select more than one output source. Only devices that are installed on your computer are active.
Select Microphone, Line In, CD, or Codec Loopback as the Input Source.
To view file information, choose Get Info from the File menu.
The File Information dialog box is displayed.
Audio provides the following information about the current file:
File name
File size in kilobytes
File length in seconds
Number of channels
Sample rate (in kilohertz)
Encoding (how many bits, what standard, etc.)
Audio Control enables you to control the volume and balance levels for playback and recording. Please refer to the following illustration for an example of the Audio Control window.
There are three menu items available:
File — controls whether or not you want Mixer Mode enabled (the default is enabled). Mixer mode enables you to listen to two audio sessions at once. For example, while listening to a Sun Microsystems broadcast you will also be able to hear the tone alerting you that you have new mail. Refer to the following illustration for an example of the Mixer mode enabled.
File is also where you will find the Exit command when you are ready to quit Audio Control.
View — controls your audio input and output. Toggling the Applications Control shows/hides (toggles) all Master and all Application processes.
Help — provides you with assistance in all areas of Audio Control. Refer to the following illustration for an example showing the Help pull-down menu.
There are two tabs, Playback and Record. Audio Control detects the type of device being used and displays the appropriate tab. The Playback window appears if used with a play-only device, such as speakers. The Record tab appears when used with a record-only device, such as a microphone.
If your device supports both play and record, you can switch between adjusting Playback (Output) and Record (Input) by selecting the corresponding tab (toggles). If you have the Playback tab selected when you check the Application Controls box, the Application control box also displays. Refer to the following illustration for an example of this.
The following controls are provided on the Master Output window:
Output Source — contains a list of available output sources. You check and uncheck sources to turn them on and off. Your choices are Built-in Speaker, Headphone, and Line Out. This list can grow to accommodate additional output devices. Volume and balance levels apply to all sources simultaneously, not to individual sources to turn them on and off.
Volume slider —for setting the master volume for all sources. The absolute level is displayed in a text label next to the control (the value is 50 in the figure above.) The displayed value changes as the slider is moved up and down.
Balance slider — for setting the balance for all sources.
Mute — for simultaneously muting all output sources.
You can control master recording parameters on the Master Recording window. Access it by selecting the Record tab at the top of the window. Please refer to the following illustration for an example of this.
The controls provided are:
Master Input — contains a list of the available input sources. You can choose only one input source at a time. The default choices are Microphone, CD ROM, and Line In. This list can grow to accommodate additional input device.
Gain (db) slider — for setting the master gain (recording volume). The level is displayed next to the control (the value is 50 in the previous figure.) The displayed value changes as the slider is moved up and down.
Monitor slider — for adjusting the volume of the incoming audio that is sent to the output device(s). It allows you to monitor the audio as it is being recorded.
Balance slider — for setting the recording balance for the selected source.
The Playback tab lets you control individual process audio output parameters. You can access it by selecting the Application Controls option from the View menu when the Playback tab is active. The new controls provided are exactly the same as those provided for the Master Output, with the exception that they are provided for one process at a time, rather than for an entire output device. Processes that are currently using audio are displayed in the list box at the top of the panel. By selecting a process, you can individually control the volume, balance, and muting of that process. If you have multiple audio channels, you can customize the individual volume and balance of each channel.
You can control individual process' audio input parameters using the
Master and Application Input screen. You access it by selecting the Application
Controls option from the View menu when the Record tab is active. Refer to
The controls provided behave exactly the same as those provided for the Master Output, with the exception that they are provided for one process at a time, rather than for an entire output device. Processes that are currently using audio are displayed in the list box at the top of the panel. By selecting a process, you can individually control the gain, and balance of that process. The Monitor volume is controllable only at the master level, so there is no Monitor Volume Slider on the Application Input panel.
This dialog allows you to view playback and recording status at the master level for each process. You can access it by selecting Status from the View menu. Audio Control detects the type of device in use. If the device supports playback, the Playback Status appears, if the device supports recording, the Record Status appears. Please refer to the following illustration.
Process List Box — this is a list of the items available for status monitoring. You can choose to view Master status or to see status for each of the running processes that are using dev/audio. You can choose only one process (or Master) to monitor at a time. As you select items in the list, the Playback and Record panes in the lower portion of the dialog update to reflect the status for the selected item being monitored.
Continuous Update Checkbox — status is displayed at the time the dialog was invoked, unless you check Continuous Update. If Continuous Update is checked, the status for the selected process is continuously monitored and updated.
Update Now Button — if Continuous Update is not turned on, you can update the display by clicking Update Now. If Continuous Update is turned on, the Update Now button is disabled (grayed out.)
The status of each of the following parameters being monitored and is represented by either an LED icon in the on or off state, or a text string with the details of the status item being displayed.
Playback and Record
Open — The device is open by a process. The device may be opened read only, write only, or read and write. Which is why there is an open for play and one for record. These will be used only when mixing is disabled.
Paused — The applications has commanded the device to pause playing or recording. Just like Open, you can have one direction paused while the other is active. Also, this will be used only when mixing is disabled.
Active — Sound is being played or recorded. In mixer mode this means at least one stream is playing or recording. It is possible that other streams will be paused. When the mixer is off then there can be only a single play and record stream, so this means that single stream is active.
Underflow — When playing there wasn't enough audio available so the device underflowed and there is silence. With the mixer this means that the stream didn't have enough sound to mix into the audio stream that is being played, so that one stream will have silence.
Open-Waiting — When the mixer is turned of this means a process is trying to open the audio device and can't because another process already has the device open. When the mixer is enabled it means a process is either trying to open the audio device a second time for the same direction, or the mixer is out of resources and is waiting for another process to close the audio device and free up a resource for use.
EOF Count — When playing it is possible to mark the audio stream so that you know when a segment has been played. This is done by doing a zero sized write and accepting signal. Each time this marker is encountered while playing the EOF Count will be incremented by one and a signal will be sent to the application.
Samples — The number of sample frames that has been played or recorded. A sample frame is all samples to play one sample time. For example, playing a mono audio stream means that one sample frame has one sample, but playing a stereo stream means that one sample frame has two samples. One for the left channel and one for the right channel.
Encoding — This combines two audio format properties, precision and encoding. Precision is the number of bits each sample uses. We support 16 bits and 8 bits. The encoding method determines any processing of the audio sample. This is usually done to compress the size of the audio stream so not as much data needs to be sent over the network or stored on disk. We support "linear" which is linear pulse code modulation, AKA linear PCM. We also support u-Law (u is for the Greek letter mu, which can't be reproduces in simple text like this, but it can in postscript), and A-Law. When combined together with precision we support 16-bit Linear PCM, 8-bit Linear PCM, 8-bit u-Law, and 8-bit A-Law. Also, linear PCM may be signed or unsigned, we support only signed.
Sample Rate — The number of times a second the audio stream is sampled and thus converted from an analog signal to a digital number for recording. Or converted from a digital number to an analog signal when playing. The higher the number the greater the accuracy of the digital signal. But a higher number also means more disk space is needed for storage or network bandwidth is needed to transfer the data.
Channels — The number of samples in a sample frame. Currently we support 1 (mono) or 2 (stereo).
Close Button — Dismisses the Status dialog.
