Solaris Common Desktop Environment: User's Guide
To Change How Objects Are Represented
  1. Choose Set View Options from the View menu.
  2. Select the representation you prefer from the Representation box.
    • By Name Only - Icons will not be displayed in File Manager. File Manager indicates objects that are folders by adding a slash (/) after their names. Executable programs have an asterisk (*) after their name.
    • By Large Icons - This is the default. The objects in File Manager will appear with their names and large icons.
    • By Small Icons - The objects in File Manager will appear with their names and small icons.
    • By Name, date, size, ... - The objects in File Manager will appear with date, size, and so on in addition to the file names and icons.
  3. Click OK or Apply.
