Use the Tab and direction keys to move the highlight to the file or folder to be moved.
Press the Spacebar to select the object.
Choose Move to from the Selected menu.
Type a name into the Destination Folder text field.
For example, if you want to move the file report into the folder /u/john, you would type /u/john.
Click OK or press Return.
If you move a folder, the entire folder and its contents are moved.
