Solaris Common Desktop Environment: User's Guide
Icon Browsing
Files with names that end in .pm or .bm contain icons. These are the files that File Manager uses to build icons. By default, you must open these files to see the icons they contain. If you enable icon browsing, File Manager displays the contents of .pm or .bm files so you don't have to open them to see what they look like.
Figure 5–5 Icon with Icon Browsing Enabled (Left) and Disabled (Right)
Graphic
To Enable Icon Browsing
  1. Copy the file /usr/dt/examples/types/language/IconBrowse.dt into your /$HOME/.dt/types folder.
  2. Open Application Manager and double-click Reload Actions in the Desktop_Controls application group.
  3. Restart File Manager.
    Note –
    The maximum default display area for icons is 38x38 pixels. So, if a picture file is larger than 38x38, the picture will be clipped and only the top left 38x38 pixels will be shown. You can increase the size of the display area for icons if you want larger images to be fully visible (see To Change the Icon Display Area Size). However, a larger display size area will slow down the opening of folders, and icons will be spread further apart in folder views.
To Disable Icon Browsing
  1. Remove your personal copy of the IconBrowse.dt file.
