Online help is available for each of the standard applications in the Common Desktop Environment (CDE). Whether you are using File Manager, Calendar, or Mailer for example, you request and display help topics in the same way. You can also browse help information on your system using the desktop Help Manager.
Other applications installed on your desktop may take advantage of using the desktop's Help System or provide help in other ways.
Here are the ways you can request Help:
Press F1—also known as the “help key”—to get context-sensitive help
Choose a command from an application's Help menu
Open Help Manager from the Front Panel to browse help on your system
Open the Help subpanel to choose help about the desktop or to choose On Item Help
When you have a question, the quickest and easiest way to get help is to press F1. When you press F1, the application you are using displays a help topic most closely related to the component—a window or button for example—that is highlighted. Because the application determines which help topic is most appropriate, this type of help is called context-sensitive.
The F1 key is a quick way to get help on an application menu or dialog box. For example, to request help about the File Manager File menu, display the File menu and press F1. File Manager displays a description of each item in the menu. Or, if a dialog box is open, pressing F1 will display an explanation of the dialog box. The F1 key is a shortcut for clicking the dialog box's Help button.
Some computers have a dedicated “Help” key on the keyboard. If yours does, it may take the place of the F1 key.
Most applications have a Help menu that contains commands for requesting different types of help such as an introduction, application tasks, or reference information.
A typical CDE Help menu includes these commands:
Overview—displays the home topic for the application. The home topic is the first topic of the application's help topic hierarchy.
Tasks—displays task instructions for most operations performed with the application.
Reference—displays reference summaries for various components, such as windows and dialog boxes, menus, and application resources.
On Item—enables you to click an item in any window of an application and view a description of the item.
Using Help—provides help on using the help windows.
About Application—displays the version and copyright information for the application.
Applications can include additional choices. Also, non-CDE applications may have different commands in their Help menus.
On Item help is interactive. It enables you to move the pointer to a specific item (such as a menu, button or dialog box) and click the item to display its corresponding help.
Choose On Item from the Help menu.
The pointer changes to a ? (question mark).
Move the pointer to an item in the application and click mouse button 1.
A description of the item is displayed.
Help Manager is a special help volume that lists all the online help registered on your system. Clicking the Help Manager control in the Front Panel opens the Help Manager help volume.
Click any of the underlined titles to view the corresponding help information. For additional instructions about using Help Manager see Browsing Help on Your System.
For convenience, the Help subpanel on the Front Panel provides help on CDE and the Front Panel (see Help Subpanel).
The Help System is built into each of the CDE applications (and possibly other applications installed on your system). When you ask for help while using an application, the application displays a help window.
Applications can use two types of help windows to display help topics: a general help window and a quick help window, shown in Figure 3–4.
General help windows have a topic tree and a topic display area. The topic tree is a list of help topics that you can browse to find help on a subject. When you choose a topic, it is displayed in the lower portion of the help window called the topic display area.
Quick help windows are streamlined help windows. A quick help window has just a topic display area and one or more buttons.
There are two ways to select a help topic. You can choose a topic from the topic tree. Or, within a help topic, you can select a hyperlink. A hyperlink is an active word or phrase that “jumps” to another related help topic. Any underlined text in a help window is a hyperlink.
Graphic images can also be used as hyperlinks. For more information about hyperlinks, see Using Hyperlinks.
The topic tree is an outline of a help volume's major topics. Subtopics are indented under main topics. The current topic, whose contents are displayed in the topic display area, is marked with an (arrow). You can scroll the topic display area to see all your choices or resize the entire help window.
You can also change the size of the topic pane. To do so, drag the sash control shown in Figure 3–5. Then release the mouse button to set the new size.
Any underlined text in a help window is a hyperlink. It is easy to “jump” to related help topics using hyperlinks—just click the underlined text.
A solid underline identifies a standard hyperlink that displays the new topic in the current help window. For example, the last paragraph in Figure 3–5 shows a hyperlink of this type.
A dashed underline indicates a definition link, which displays a quick help window.
A graphic—an icon, for example—can also be a hyperlink. A grey open-cornered border identifies a graphic hyperlink. Figure 3–6 shows the different hyperlink formats that can be used in help topics.
Most hyperlinks display the related topic in the same window. However, if you choose a hyperlink that jumps to a help topic for another application, a new window is displayed. Links that jump from one application's online help into another's are called cross-volume or cross-application hyperlinks.
To move between help topics, use these commands on the Navigate menu:
Backtrack—returns to the previous topic. Backtrack enables you to return to each topic you have visited.
History—displays a History dialog box that lists help volumes and topics you have visited. Select a help topic to re-display it.
Home Topic—returns to the home topic, or beginning of the help volume.
For convenience, Backtrack and History are also provided as push buttons.
In a general help window, you can also use the Help pop-up menu as a shortcut. The pop-up menu includes both Backtrack and Home Topic, which are frequently used commands.
Quick help windows do not have a pop-up menu.
Point to the topic display area and press mouse button 3.
Choose Backtrack or Home Topic.
Because hyperlinks can quickly take you from one piece of information to another, you may need to know where you are. A quick look at your help window can give you the information you need.
The line located below the menu bar reports the name of the volume you are viewing. This is helpful when you have explored several help volumes using Help Manager, the help index, or cross-volume links.
Within the topic tree, the first item is the home topic, or the beginning of the help volume. After exploring topics, you can easily return to the home topic by scrolling to the top of the topic tree. Or, you can choose Home Topic from the Navigate menu or pop-up menu.
An (arrow) points to the title of the current topic. As you choose topics, the arrow moves to identify your selection. Scrolling the topic tree shows you where you are located relative to other topics.
A general help window keeps track of the topics that you have visited. The History command opens a dialog box that lists the help volumes and help topics you have visited.
Click the History button.
Choose the title of the help volume or topic that you want to display.
When you're done, click Close.
Like a book, a help volume has an index of important words and phrases that you can use to find help topics on a subject. You can browse or search the index of the current volume, selected volumes, or all help volumes available on your system.
Because the help index can be quite large even for a single volume, index entries can be expanded or contracted. A + (plus) sign indicates that the index entry relates to more than one help topic. The number shows the count of help topics. You can click the index item to list the topics.
For instance, the result of an index search for the word “display” is shown in Figure 3–9. The -36 prefix tells you that there are 36 index entries that contain the keyword “display.” Clicking any title marked by a + (plus) expands the list and the + (plus) changes to a - (minus) sign. The last index entry shown in the figure has been expanded in this way.
The help index is available only in a general help window.
To open the index, click the Index button.
The index lists all of the entries for the current help volume. You can choose All Volumes to view an index for all available help volumes or choose Selected if you want to select only certain volumes.
Select the Entries with field, type the word or phrase you are looking for, and press Return.
Index searches are not case sensitive. Wildcards such as * (asterisk) and ? (question mark) can be used (see Pattern Searches below).
Select the index entry you want to view.
If the entry has a + (plus sign) prefix, the list will expand to show additional choices. Then select a help topic to view.
You may view as many topics as you want.
Click Close when you are done.
In a pattern search certain characters (known as “wildcards”) have special meaning. You can combine these characters in a variety of ways.
Two frequently used wildcards are asterisk (*) and question mark (?). The * matches any string of characters (including no characters), and ? matches any single character. Other wildcards include:
. (period)—matches any character
| (vertical bar)—specifies two search patterns and matches either pattern (logical OR)
( ) (parentheses)—encloses a pattern expression
To search for a character that has special meaning in a regular expression, precede the character with a \ (backslash).
mouse.*clicking—matches entries that contain the word “mouse” followed by any number of characters followed by “clicking”
mouse | click—matches entries that contain the word “mouse” or “click”
(session | style)*manager—matches entries that contain “Session Manager” or “Style Manager”
You can browse all application help volumes registered on your system without having to start each individual application—just start Help Manager from the Front Panel.
At the top level, Help Manager groups help volumes into help families. For example, the help family Common Desktop Environment lists help volumes for the standard desktop applications. You can browse and display any of the volumes listed.
Click the Help Manager control in the Front Panel (see Figure 3–2).
A help window displays a list of help families with online help. This is the top level of Help Manager.
Scroll the window to find the product group you are interested in and click its title (underlined).
This lists the help volumes available for that product.
To open a particular help volume, click its title (underlined text).
To return to the top level of Help Manager, click the Top Level button.
For example, to browse File Manager's online help:
Click the Help Manager control.
Choose Common Desktop Environment.
Scroll the list of help volumes until you see File Manager Help.
Click File Manager Help.
File Manager's help is displayed. This is the same help information you would see if you opened File Manager and chose Overview from the Help menu.
Choose New Window from the Help Manager File menu.
The current help window is duplicated. You can size the new window and select topics independently of the original window.
To remove the window, choose Close from the File menu.
The New Window command is only available in the Help Manager help window (see Browsing Help on Your System).
Online manuals can be displayed by choosing AnswerBook2 from the Help subpanel. The current versions of CDE manuals are normally available on the Internet at the URL http://docs.sun.com.
Manual reference pages, traditionally known as “man pages,” can be displayed using the Man Page Viewer action. The action icon is located in the Desktop_Apps folder in Application Manager.
Click the Application Manager control in the Applications subpanel of the Front Panel.
Application Manager opens.
Double-click the Desktop_Apps icon.
Double-click the Man Page Viewer icon.
A dialog box is displayed, prompting you to enter a man page name.
Type the name of the man page you want to see and optional command line options, and press Return.
The man page is displayed in a quick help window.
Click Close to dismiss the man page.
For a list of command line options available with the man command, display the man(1) man page.
Sometimes you may want to have a printed version of a help topic for a particular application. You can print an individual help topic, a table of contents and index, or the entire help volume. Printing options, such as paper size, number of copies, and destination printer, can also be set in the Print dialog box.
Printed help topics are directed to your default printer unless you provide a different printer name in the dialog box. Printed output is text only.
Choose Print from the File menu. (In a quick help window, click the Print button.)
You can use the default values in the Print dialog box and skip to step 5 or enter new values for your print job.
Optional. Type the name of the printer that you want to use.
Optional. Type the number of copies to print.
Optional. Click the paper size button to choose a paper size.
Select the topic or topics you want to print.
Current Topic (the default)—prints only the current topic
Current and Subtopics—prints the current topic and its subtopics
Table of Contents and Index—prints the help volume table of contents and index
Entire Volume—prints the contents of the help volume including the table of contents and index
Click Print.
The Print dialog box displays the name of your default printer. You can change the default printer name by modifying the LPDEST environment variable. You can also change the printer for a specific application by modifying the application's application defaults file.
Edit your HomeDirectory/.Xdefaults file by adding this resource:
application_name*printer printer.name
If you do not have an .Xdefaults file, create the file in your home directory.
You want to direct all printed help topics of an application named ImageScan to a printer named laser2 rather than to your default printer.
Add this resource to your .Xdefaults file:
ImageScan*printer: laser2
You can change the colors of the topic tree or topic display area of a help window by setting application resources. Choosing contrasting colors is important. This ensures that text (foreground color) will be visible against the background color.
Edit your HomeDirectory/.Xdefaults file by adding these resources:
application_name*DtHelpDialog*DisplayArea.foreground: color application_name*DtHelpDialog*DisplayArea.background: color application_name*DtHelpDialog*TocArea.foreground: color application_name*DtHelpDialog*TocArea.background: color application_name*DtHelpQuickDialog*DisplayArea.foreground: color application_name*DtHelpQuickDialog*DisplayArea.background: color
Substitute the name of the application whose help windows you want to change for application_name.
You can ask your system administrator for a list of colors that you can use or refer to your system documentation.
Save and close the file.
When you restart your application, it will use the new color values for the topic tree and topic display area in its help windows.
For example, these resource entries change the foreground and background colors of the topic tree (TocArea) and topic display area (DisplayArea) for an application named DtCardCatalog.
DtCardCatalog*DtHelpDialog*TocArea.foreground: yellow DtCardCatalog*DtHelpDialog*TocArea.background: blue DtCardCatalog*DtHelpDialog*DisplayArea.foreground: yellow DtCardCatalog*DtHelpDialog*DisplayArea.background: blue DtCardCatalog*DtHelpQuickDialog*DisplayArea.foreground: yellow DtCardCatalog*DtHelpQuickDialog*DisplayArea.background: blue
Quick help windows do not have a topic tree, so the TocArea resource is omitted.
