An alias is a private name for one or more user names (or user addresses). By creating a distribution list of user addresses to which you frequently send mail and giving the list a name, you can select the alias in the To or Cc fields instead of typing each address every time you send a message (see Figure 18–1).
The name you give to your alias can be descriptive of a group of users, or just a name you will remember. These aliases are also displayed as Personal Alias cards in Address Manager (see Alias Cards).
Choose Aliases from the Options menu in the main window, from the Format menu in a Compose window, or from the To or Cc button menu in the Compose window.
The Aliases Options dialog box is displayed.
Type the name for your alias in the Alias field.
Type the user addresses that will make up the alias in the Addresses field.
Each of these addresses should be in the form username@hostname and be separated by a comma, a space, or both.
Click Add to add the information in the Alias and Addresses fields to the scrolling list.
(Optional) To change an alias, select it and edit the Alias or Addresses field, as appropriate, then click Change.
(Optional) To remove an alias, select it and click Delete.
Click OK or Apply to make the settings take effect.
You can also work with aliases using Address Manager (see To Create a Personal Alias Card).
