You can search for mail messages within a mailbox according to the search criteria that you define. Basic search criteria fields in the Basic window of the Search dialog box include: the addressees (To), the sender (From), the subject (Subject), the carbon copy recipients (Cc), and the message text, including the headers (Entire Message).
By creating a search script in the Advanced window of the Search dialog box with keywords and arguments, you can define more sophisticated search criteria for finding messages.
The tables that follow show the keywords you can use in search scripts, grouped under the following categories:
Headers – Keywords that denote the headers or the text part of the messages (Table 10–1)
Dates – Keywords that indicate when the messages were sent (Table 10–2)
States – Keywords that describe the status of the messages (Table 10–3)
Operators – Keywords that join together other keywords to form a search criterion (Table 10–4)
Those keywords you can type manually but are not available through the menus in the Advanced window of the Search dialog box are marked with an asterisk (*).
Keyword |
Explanation |
TO |
FROM |
SUBJECT |
Cc |
TEXT |
A keyword that pertains to the entire message, including headers and attachments |
BCC |
HEADER* |
A keyword to use according to the syntax: header HeaderName HeaderValue, such as header x-sun-charset us-ascii |
BODY* |
A keyword that applies to the message text and the text attachments, but not the headers |
Table 10–2 lists and describes the Dates keywords.
The date format is dd-mmm-yyyy (for example, 02-Apr-1996).
Keyword |
Explanation |
BEFORE |
SINCE |
ON |
DURING |
SENTSINCE* |
SENTBEFORE* |
SENTON* |
TODAY |
An argument for the keywords that are associated with dates, such as before |
YESTERDAY |
Same as above |
LASTWEEK |
Same as above |
THISMONTH |
Same as above |
LASTMONTH |
Same as above |
JANUARY..DECEMBER |
SUNDAY..SATURDAY |
Table 10–3 lists and describes the States keywords.
Table 10–3 States Search Keywords|
Keyword |
Explanation |
READ |
UNREAD |
NEW* |
OLD* |
DELETED* |
A keyword for messages that you have deleted, but not permanently |
UNDELETED* |
RECENT* |
FLAGGED* |
ANSWERED* |
UNANSWERED* |
KEYWORD* |
UNKEYWORD* |
DRAFT* |
UNDRAFT* |
ALL* |
A keyword that denotes all the messages in the mailbox |
LARGER/SMALLER* |
A keyword that requires two arguments, such as smaller 300, the numeric denoting bytes |
Table 10–4 lists and describes the search operators.
Table 10–4 Search Operators|
Operator |
Explanation |
AND |
OR |
~ (not) |
A symbol that represents the logical notoperator. Place it in front of the search keyword, for example: ~ text "good morning" |
A symbol that denotes the beginning of an expression |
A symbol that denotes the end of an expression |
Search scripts are not case sensitive.
Here are some examples:
To search for messages that were sent from john in April with either “urgent” or “important” in the subject line:
from john and (subject urgent or subject important) and during april
To search for messages that were sent from bill with no carbon copy to tigerteam and not yet read:
from bill and ~(cc tigerteam) and unread
To search for messages that were addressed to bill or sent with a carbon copy to bill, with “monthly report” in the message, including the headers and attachments:
(to bill or cc bill) and text “monthly report”
Choose Search from the Message menu.
The Search dialog box is displayed.
Type the text you want to search for in the appropriate field.
You can search for a match on one or more of the To, From, Subject, or Cc fields. If you type the criteria in multiple fields, Mailer searches for messages that match all of the criteria.
Within each field, Mailer considers the input as one criterion even if there are multiple strings separated by spaces or commas. For example, if you type wood smith in the To field, Mailer looks for a message that is addressed to wood smith, not wood or smith.
The fields are not case-sensitive.
Click Search Down or Search Up to find the next or previous matching message in your mailbox. To find all the matches, click Select All.
To remove all the text in the fields in the Search dialog box, click Clear.
