Solaris Common Desktop Environment: User's Guide
To Print an Open Document
  1. Open the document in Text Editor.
  2. Choose Print from the File menu or press Control+P.
    The Print dialog box displays the name of your system's printer and enables you to set printing options. By default, your document is printed on your system printer. If desired, you can direct your job to a different printer.
    Figure 12–14 Print dialog box
    Graphic
  3. Optional. Set any of these printing options:
    • Type the number of copies to print.
    • Type text to appear on the printer banner page.
    • Click Print Page Numbers if you want to number the pages.
    • Type command-line printer options.
  4. Click Print.
    The Print dialog box closes when you print your document. To close the dialog box without printing your file, click Cancel.
