The open(9E) entry point is used to gain access to a given device. The open(9E) routine of a block driver is called when a user thread issues an open(2) or mount(2) system call on a block special file associated with the minor device, or when a layered driver calls open(9E). See File I/O for more information.
The open(9E) entry point should check for the following:
The device can be opened; for example, it is online and ready.
The device can be opened as requested; the device supports the operation, and the device's current state does not conflict with the request.
The caller has permission to open the device.
Example 11–2 demonstrates a block driver open(9E) entry point.
static int
xxopen(dev_t *devp, int flags, int otyp, cred_t *credp)
minor_t instance;
struct xxstate *xsp;
instance = getminor(*devp);
xsp = ddi_get_soft_state(statep, instance);
if (xsp == NULL)
return (ENXIO);
mutex_enter(&xsp->mu);
* only honor FEXCL. If a regular open or a layered open
* is still outstanding on the device, the exclusive open
* must fail.
if ((flags & FEXCL) && (xsp->open || xsp->nlayered)) {
mutex_exit(&xsp->mu);
return (EAGAIN);
switch (otyp) {
case OTYP_LYR:
xsp->nlayered++;
break;
case OTYP_BLK:
xsp->open = 1;
break;
default:
return (EINVAL);
return (0);
The otyp argument is used to specify the type of open on the device. OTYP_BLK is the typical open type for a block device. A device can be opened several times with otyp set to OTYP_BLK, although close(9E) will be called only once when the final close of type OTYP_BLK has occurred for the device. otyp is set to OTYP_LYR if the device is being used as a layered device. For every open of type OTYP_LYR, the layering driver issues a corresponding close of type OTYP_LYR. The example keeps track of each type of open so the driver can determine when the device is not being used in close(9E).
