Function Name |
Description |
zero return function |
nodev |
error return function |
nochpoll |
error return function for non-pollable devices |
ASSERT |
expression verification |
bcopy |
copy data between address locations in the kernel |
bzero |
clear memory for a given number of bytes |
bcmp |
compare two byte arrays |
ddi_ffs |
find first bit set in a long integer |
ddi_fls |
find last bit set in a long integer |
swab |
swap bytes in 16-bit halfwords |
strcmp |
compare two null-terminated strings |
strncmp |
compare two null-terminated strings, with length limit |
strlen |
determine the number of non-null bytes in a string |
strcpy |
copy a string from one location to another |
strncpy |
copy a string from one location to another, with length limit |
strchr |
find a character in a string |
sprintf |
format characters in memory |
vsprintf |
numtos |
convert integer to decimal string |
stoi |
convert decimal string to an integer |
max |
return the larger of two integers |
min |
return the lesser of two integers |
va_arg |
handle variable argument list |
va_copy |
va_end |
va_start |
