This section provides a tutorial for some of the mdb debugger commands most applicable to driver authors. Note that the information presented here is dependent on the type of system used. A Sun Blade™ 100 workstation running the 64-bit kernel was used to produce these examples.
The Solaris Modular Debugger Guide provides details about each debugger command discussed here, as well as more information about all aspects of mdb. Online help is available from within mdb using the ::help built-in command.
mdb provides a powerful facility for displaying kernel data structures, so that earlier kadb(1) and mdb(1) debugger macros are no longer needed. Starting in Solaris 9, the operating system kernel maintains a highly compressed database of data structure type information in nonpageable system memory. This means that when a crash occurs, this type information is saved as part of the crash dump.
Here is an example of using the kernel type information to display all of the fields of a scsi_pkt structure:
> 7079ceb0::print -t 'struct scsi_pkt'
opaque_t pkt_ha_private = 0x7079ce20
struct scsi_address pkt_address = {
struct scsi_hba_tran *a_hba_tran = 0x70175e68
ushort_t a_target = 0x6
uchar_t a_lun = 0
uchar_t a_sublun = 0
opaque_t pkt_private = 0x708db4d0
int (*)() *pkt_comp = sd_intr
uint_t pkt_flags = 0
int pkt_time = 0x78
uchar_t *pkt_scbp = 0x7079ce74
uchar_t *pkt_cdbp = 0x7079ce64
ssize_t pkt_resid = 0
uint_t pkt_state = 0x37
uint_t pkt_statistics = 0
uchar_t pkt_reason = 0
Each data structure member is presented along with its type. Nested structures are expanded for easy viewing. ::print can also decode arrays and unions.
It is frequently helpful to discover the size of a particular kernel data structure; doing so is simple, using the ::sizeof dcmd:
> ::sizeof 'struct scsi_pkt' sizeof (struct scsi_pkt) = 0x58
You can also locate the offset of a field within a data structure:
> ::offsetof 'struct scsi_pkt' pkt_state offsetof (pkt_state) = 0x48
The -a option may be used to view the offset of each member of a data structure; if no address is specified to ::print, the output begins at address 0, providing the offset of each field:
> ::print -at 'struct scsi_pkt'
0 opaque_t pkt_ha_private
8 struct scsi_address pkt_address {
8 struct scsi_hba_tran *a_hba_tran
10 ushort_t a_target
12 uchar_t a_lun
13 uchar_t a_sublun
18 opaque_t pkt_private
20 int (*)() *pkt_comp
28 uint_t pkt_flags
2c int pkt_time
30 uchar_t *pkt_scbp
38 uchar_t *pkt_cdbp
40 ssize_t pkt_resid
48 uint_t pkt_state
4c uint_t pkt_statistics
50 uchar_t pkt_reason
The ::print, ::sizeof and ::offsetof facilities make it possible to more rapidly debug problems which arise when your driver interacts with the Solaris kernel.
This facility provides access to “raw” kernel data structures. You may examine any structure whether it appears as part of the DDI or not; therefore, refrain from relying on any data structure that is not explicitly part of the DDI.
These dcmds may only be used with objects that contain compressed symbolic debugging information designed for use with mdb. This information is currently only available for certain Solaris kernel modules. The SUNWzlib (32-bit) or SUNWzlibx (64-bit) decompression software must be installed in order to process the symbolic debugging information.
mdb provides the ::prtconf dcmd to display the kernel device tree. The output of this dcmd is similar to the output of the prtconf(1M) command:
> ::prtconf
300015d3e08 SUNW,Sun-Blade-100
300015d3c28 packages (driver not attached)
300015d3868 SUNW,builtin-drivers (driver not attached)
300015d3688 deblocker (driver not attached)
300015d34a8 disk-label (driver not attached)
300015d32c8 terminal-emulator (driver not attached)
300015d30e8 obp-tftp (driver not attached)
300015d2f08 dropins (driver not attached)
300015d2d28 kbd-translator (driver not attached)
300015d2b48 ufs-file-system (driver not attached)
300015d3a48 chosen (driver not attached)
300015d2968 openprom (driver not attached)
The node can then be displayed using a macro (such as the $<devinfo_brief macro) or the ::devinfo dcmd:
> 300015d3e08::devinfo
System properties at 0x300015abdc0:
name='relative-addressing' type=int items=1
value=00000001
name='MMU_PAGEOFFSET' type=int items=1
value=00001fff
name='MMU_PAGESIZE' type=int items=1
value=00002000
name='PAGESIZE' type=int items=1
value=00002000
Driver properties at 0x300015abe00:
name='pm-hardware-state' type=string items=1
value='no-suspend-resume'
> 300015d3e08$<devinfo_brief
============== devinfo 300015d3e08
binding_name
0x300013b3058: SUNW,Sun-Blade-100
node_name
0x300013b3118: SUNW,Sun-Blade-100
addr
0x300015b1760:
node_state
6 DS_READY
major (hex)
1
0x300015d3e08: parent child sibling
0 300015d3c28 0
Use ::prtconf to see where your driver has attached in the device tree, and to display device properties. You can also specify the verbose (-v) flag to ::prtconf to display the properties for each device node:
> ::prtconf -v
DEVINFO NAME
value=00000001
value=00001fff
value=00002000
value=00002000
300015ce798 pci10b9,5229, instance #0
Driver properties at 0x300015ab980:
name='target2-dcd-options' type=any items=4
value=00.00.00.a4
name='target1-dcd-options' type=any items=4
value=00.00.00.a2
name='target0-dcd-options' type=any items=4
value=00.00.00.a4
Another way to locate instances of your driver is the ::devbindings dcmd. Given a driver name, it displays a list of all instances of the named driver:
> ::devbindings dad
300015ce3d8 ide-disk (driver not attached)
300015c9a60 dad, instance #0
System properties at 0x300015ab400:
name='lun' type=int items=1
value=00000000
name='target' type=int items=1
value=00000000
name='class_prop' type=string items=1
value='ata'
name='type' type=string items=1
value='ata'
name='class' type=string items=1
value='dada'
300015c9880 dad, instance #1
System properties at 0x300015ab080:
value=00000000
value=00000002
value='ata'
value='ata'
value='dada'
A common problem when debugging a driver is retrieving the soft state for a particular driver instance. The soft state is allocated with the ddi_soft_state_zalloc(9F) routine and obtained by drivers using ddi_get_soft_state(9F). If you know the name of the soft state pointer (the first argument to ddi_soft_state_init(9F)), mdb enables you to retrieve the soft state for a particular driver instance using the ::softstate dcmd:
> *bst_state::softstate 0x3 702b7578
In this case, ::softstate is used to fetch the soft state for instance 3 of the bst sample driver. This pointer points to a bst_soft structure used by the driver to track state for this instance.
The ::findleaks dcmd provides powerful and efficient detection of memory leaks in kernel crash dumps. The full set of kernel-memory debugging features should be enabled for ::findleaks to be effective. For more information see kmem_flags. Running ::findleaks during driver development and testing can detect code which is leaking memory and wasting kernel resources. See “Debugging With the Kernel Memory Allocator” in the Solaris Modular Debugger Guide for a complete discussion of ::findleaks.
Use ::findleaks to detect and eliminate kernel memory leaks caused by your code. Code that leaks kernel memory can render the system vulnerable to denial-of-service attacks.
