The modular debugger, mdb, provides sophisticated debugging support for analyzing kernel problems. This section provides an overview of mdb features. For a more complete discussion of mdb, refer to the Solaris Modular Debugger Guide.
mdb command syntax is compatible with the kadb syntax and mdbcan execute all of the kadb (and legacy adb) macros. These are stored in /usr/lib/adb and in /usr/platform/`uname -i`/lib/adb for 32-bit kernels; and in /usr/lib/adb/sparcv9 and /usr/platform/`uname -i`/lib/adb/sparcv9 for 64-bit kernels.
In addition to macro files, mdb supports debugger commands (or dcmds). These dcmds can be dynamically loaded at runtime from a set of debugger modules. mdb provides a first-class programming API for implementing debugger modules so that driver developers can implement their own custom debugging support. mdb also provides a host of usability features, such as command line editing, command history, an output pager, and online help.
mdb provides a rich set of modules and dcmds for debugging the Solaris kernel and associated modules and device drivers. Some of the activities these facilities enable you to do include:
formulate complex debugging queries
locate all the memory allocated by a particular thread
print a visual picture of a kernel STREAM
determine what type of structure a particular address refers to
locate leaked memory blocks in the kernel
analyze memory to locate stack traces
In earlier versions of the Solaris operating environment, adb(1) was the recommended tool for post-mortem analysis. In the Solaris 9 operating environment, mdb(1) is the recommended tool for post-mortem analysis. It provides an upward-compatible syntax and feature set that surpass the set of commands available from the legacy crash(1M) utility, which has been removed from Solaris 9.
To get started, type mdb and supply it with a system crash dump:
% cd /var/crash/testsystem % ls bounds unix.0 vmcore.0 % mdb unix.0 vmcore.0 Loading modules: [ unix krtld genunix ufs_log ip usba s1394 cpc nfs ] > ::status debugging crash dump vmcore.0 (64-bit) from testsystem operating system: 5.9 Generic (sun4u) panic message: zero dump content: kernel pages only
When mdb responds with the '>' prompt, it is ready for commands. To examine the running kernel on a live system, type:
# mdb -k Loading modules: [ unix krtld genunix ufs_log ip usba s1394 ptm cpc ipc nfs ] > ::status debugging live kernel (64-bit) on testsystem operating system: 5.9 Generic (sun4u)
