This section describes the kadb(1M) macros that can be used to retrieve information from the kernel about a device during a debugging session.
devinfo_brief |
Prints a brief summary of a dev_info_t structure; the name and addr fields are shown in string form and are used in the /devices path to the node |
devinfo |
Prints devinfo_brief information for a dev_info_t structure followed by an in-order dump of all fields |
devinfo.parent |
Prints devinfo_brief information for the specified node and its parents all the way back to the root of the devinfo tree |
devinfo.sibling |
Prints devinfo_brief information for all siblings of the specified node; you see all sibling nodes if you start at the parent's child |
devinfo.minor |
Prints the ddi_minor_data structure for all minor name nodes associated with the specified device node |
devinfo.prop |
Prints all the property lists associated with the specified device node |
devinfo_major |
Prints devinfo_brief information for all device nodes associated with the specified driver major number |
devt |
Breaks a dev_t into its major and minor parts and prints the values in hexadecimal and decimal |
devnames |
Prints the contents of the specified devnames structure |
devnames_major |
Prints the contents of the devnames structure for the specified major number |
bus_op |
Prints the contents of a bus_ops structure |
The devinfo commands, such as devinfo and devinfo_brief, return a node_state value, which may be one of the following:
This device node has been linked into the kernel's device tree, but the system has not yet found a driver for it.
The node is bound to a driver, but the driver's probe(9E) routine has not yet been called.
The parent nexus has assigned a bus address for the driver and completed implementation-specific initializations, but the driver's probe(9E) routine has not yet been called.
The driver's probe(9E) routine returned successfully.
The driver's attach(9E) routine returned successfully.
The device is fully configured.
