The examples in this section show how some of the device-related macros can be used to debug a driver.
The following ls -l command shows how the /devices path fits into the devinfo structure:
# ls -l /dev/ttya
lrwxrwxrwx 1 root root 6 Aug 17 17:50 /dev/ttya -> term/a
# ls -l /dev/term/a
lrwxrwxrwx 1 root root 32 Aug 17 17:42 /dev/term/a ->
../../devices/obio/zs@0,100000:a
Example 18–1 shows how to obtain information about the /dev/ttya device from the devinfo structure and other kernel structures, beginning with devinfo_major.
# ls -lL /dev/ttya
crw-rw-rw- 1 root sys 29, 0 Aug 17 17:42 /dev/ttya
# ~stopped at:
edd000d8: ta %icc,%g0 + 125
kadb[0]: 0t29$<devinfo_major
============== devinfo f5f0dcd0
binding_name
0xf5bb38f8: zs
node_name
0xf5bb38f8: zs
addr
0xf5f8d6a0: 0,100000
node_state
6 DS_READY
major (hex)
1d
instance
0
0xf5f0dcd0: parent child sibling
f5f0f380 0 f5f0dba8
============== devinfo f5f0dba8
binding_name
0xf5bb3a18: zs
node_name
0xf5bb3a18: zs
addr
0xf5f90560: 0,0
node_state
6 DS_READY
major (hex)
1d
instance
1
0xf5f0dba8: parent child sibling
f5f0f380 0 f5f0da80
Example 18–2 shows the use of the devinfo_brief macro. It also shows the use of top_devinfo. top_devinfo is a pointer to the root of the devinfo tree (rootnexus)—all other devinfo nodes are descendants of this node. If you want to look at the device tree top-down in the debugger, this is where you start.
kadb[0]: *top_devinfo$<devinfo_brief
============== devinfo f5f0fde8
binding_name
0xf5bc6a30: SUNW,SPARCstation-10
node_name
0xf5bc6af8: SUNW,SPARCstation-10
addr
0xf5f90950:
node_state
6 DS_READY
major (hex)
1
0xf5f0fde8: parent child sibling
0 f5f0fcc0 0
