The syntax for devmap_dup(9E) is:
int xxdevmap_dup(devmap_cookie_t handle, void *devprivate,
devmap_cookie_t new_handle, void **new_devprivate);
This entry point is called when a device mapping is duplicated, for example, by a user process calling fork(2). The driver is expected to generate new driver private data for the new mapping.
Mapping handle of the mapping being duplicated
Mapping handle of the mapping that was duplicated
Pointer to the driver private data associated with the mapping being duplicated
Should be set to point to the new driver private data for the new mapping
Mappings created with devmap_dup() will, by default, have their mapping translations invalidated. This will force a call to the devmap_access(9E) entry point the first time the mapping is accessed.
Example 13–4 shows a devmap_dup() routine.
static int
struct xxctx *ctxp = devprivate;
struct xxstate *xsp = ctxp->xsp;
struct xxctx *newctx;
/* Create a new context for the duplicated mapping */
newctx = kmem_alloc(sizeof (struct xxctx), KM_SLEEP);
newctx->xsp = xsp;
newctx->handle = new_handle;
newctx->offset = ctxp->offset;
newctx->flags = ctxp->flags;
newctx->len = ctxp->len;
mutex_enter(&xsp->ctx_lock);
if (ctxp->flags & MAP_PRIVATE) {
newctx->context = kmem_alloc(XXCTX_SIZE, KM_SLEEP);
bcopy(ctxp->context, newctx->context, XXCTX_SIZE);
} else {
newctx->context = xsp->ctx_shared;
mutex_exit(&xsp->ctx_lock);
*new_devprivate = newctx;
return(0);
