The DMA attribute structure has the following members:
typedef struct ddi_dma_attr {
uint_t dma_attr_version; /* version number */
uint64_t dma_attr_addr_lo; /* low DMA address range */
uint64_t dma_attr_addr_hi; /* high DMA address range */
uint64_t dma_attr_count_max; /* DMA counter register */
uint64_t dma_attr_align; /* DMA address alignment */
uint_t dma_attr_burstsizes; /* DMA burstsizes */
uint32_t dma_attr_minxfer; /* min effective DMA size */
uint64_t dma_attr_maxxfer; /* max DMA xfer size */
uint64_t dma_attr_seg; /* segment boundary */
int dma_attr_sgllen; /* s/g length */
uint32_t dma_attr_granular; /* granularity of device */
uint_t dma_attr_flags; /* Bus specific DMA flags */
} ddi_dma_attr_t;
Version number of the attribute structure. It should be set to DMA_ATTR_V0.
Lowest bus address that the DMA engine can access.
Highest bus address that the DMA engine can access.
Specifies the maximum transfer count that the DMA engine can handle in one cookie. The limit is expressed as the maximum count minus one. It is used as a bit mask, so it must also be one less than a power of two.
Specifies additional alignment requirements for any allocated DMA resources. This field can be used to force more restrictive alignment than implicitly specified by other DMA attributes, such as alignment on a page boundary.
Specifies the burst sizes that the device supports. (A burst size is the amount of data the device can transfer before relinquishing the bus.) This member is a binary encoding of burst sizes, assumed to be powers of two. For example, if the device is capable of doing 1-, 2-, 4-, and 16-byte bursts, this field should be set to 0 x 17. The system also uses this field to determine alignment restrictions.
Minimum effective transfer size the device can perform. It also influences alignment and padding restrictions.
Describes the maximum number of bytes that the DMA engine can transmit or receive in one I/O command. This limitation is only significant if it is less than (dma_attr_count_max + 1) * dma_attr_sgllen.
Upper bound of the DMA engine's address register. This is often used where the upper 8 bits of an address register are a latch containing a segment number, and the lower 24 bits are used to address a segment. In this case, dma_attr_seg would be set to 0xFFFFFF, which prevents the system from crossing a 24-bit segment boundary when allocating resources for the object.
Specifies the maximum number of entries in the scatter-gather list. It is the number of cookies that the DMA engine can consume in one I/O request to the device. If the DMA engine has no scatter-gather list, this field should be set to one.
This field describes the granularity of the device's DMA transfer ability, in units of bytes. This value is used to specify, for example, the sector size of a mass storage device. DMA requests will be broken into multiples of this value. If there is no scatter-gather capability, then the size of each DMA transfer will be a multiple of this value. If there is scatter-gather capability, then a single segment will not be smaller than the minimum transfer value, but can be less than the granularity; however the total transfer length of the scatter-gather list will be a multiple of the granularity value.
This field can be set to DDI_DMA_FORCE_PHYSICAL, which indicates that the system should return physical rather than virtual I/O addresses if the system supports both. If the system does not support physical DMA, the return value from ddi_dma_alloc_handle(9F) will be DDI_DMA_BADATTR. In this case, the driver has to clear DDI_DMA_FORCE_PHYSICAL and retry the operation.
