Device drivers usually allocate a mutex for each driver data structure. The mutex is typically a field in the structure and is of type kmutex_t. mutex_init(9F) is called to prepare the mutex for use. This is usually done at attach(9E) time for per-device mutexes and _init(9E) time for global driver mutexes.
For example,
struct xxstate *xsp; ... mutex_init(&xsp->mu, NULL, MUTEX_DRIVER, NULL); ...
For a more complete example of mutex initialization, see Chapter 5, Driver Autoconfiguration.
The driver must destroy the mutex with mutex_destroy(9F) before being unloaded. This is usually done at detach(9E) time for per-device mutexes and _fini(9E) time for global driver mutexes.
