Every section of the driver code that needs to read or write the shared data structure must do the following:
Acquire the mutex
Access the data
Release the mutex
The scope of a mutex—the data it protects—is entirely up to the programmer. A mutex protects some particular data structure because the programmer chooses to do so and uses it accordingly. A mutex protects a data structure only if every code path that accesses the data structure does so while holding the mutex.
