The Solaris DDI/DKI divides the software interface to SCSI devices into two major parts: target drivers and host bus adapter (HBA) drivers. Target refers to a driver for a device on a SCSI bus, such as a disk or a tape drive. Host bus adapter refers to the driver for the SCSI controller on the host machine. SCSA defines the interface between these two components. This chapter discusses target drivers only. See Chapter 15, SCSI Host Bus Adapter Drivers for information on host bus adapter drivers.
The terms “host bus adapter” or “HBA” used in this manual are equivalent to the phrase “host adapter” defined in SCSI specifications.
This chapter provides information on the following subjects:
Target drivers can be either character or block device drivers, depending on the device. Drivers for tape drives are usually character device drivers, while disks are handled by block device drivers. This chapter describes how to write a SCSI target driver and discusses the additional requirements that SCSA places on block and character drivers for SCSI target devices.
The following reference documents provide supplemental information needed by the designers of target drivers and host bus adapter drivers.
Small Computer System Interface 2 (SCSI-2), ANSI/NCITS X3.131-1994, Global Engineering Documents, 1998. ISBN 1199002488.
The Basics of SCSI, Fourth Edition, ANCOT Corporation, 1998. ISBN 0963743988.
Also refer to the SCSI command specification for the target device, provided by the hardware vendor.
The Sun Common SCSI Architecture (SCSA) is the Solaris DDI/DKI programming interface for the transmission of SCSI commands from a target driver to a host bus adapter driver. This interface is independent of the type of host bus adapter hardware, the platform, the processor architecture, and the SCSI command being transported across the interface.
By conforming to the SCSA, the target driver can pass any SCSI command to a target device without knowledge of the hardware implementation of the host bus adapter.
The SCSA conceptually separates building the SCSI command (by the target driver) from transporting the SCSI command and data across the SCSI bus. The architecture defines the software interface between high-level and low-level software components. The higher level software component consists of one or more SCSI target drivers, which translate I/O requests into SCSI commands appropriate for the peripheral device. Figure 14–1 illustrates the SCSI architecture.
The lower-level software component consists of a SCSA interface layer and one or more host bus adapter drivers. The target driver is responsible for the generation of the proper SCSI commands required to execute the desired function and for processing the results.
Assuming no transport errors occur, the following steps describe the general flow of control for a read or write request.
The target driver's read(9E) or write(9E) entry point is invoked. physio(9F) is used to lock down memory, prepare a buf structure, and call the strategy routine.
The target driver's strategy(9E) routine checks the request and allocates a scsi_pkt(9S) using scsi_init_pkt(9F). The target driver initializes the packet and sets the SCSI command descriptor block (CDB) using the scsi_setup_cdb(9F) function. The target driver also specifies a timeout and provides a pointer to a callback function, which is called by the host bus adapter driver on completion of the command. The buf(9S) pointer should be saved in the SCSI packet's target-private space.
The target driver submits the packet to the host bus adapter driver using scsi_transport(9F). The target driver is then free to accept other requests. The target driver should not access the packet while it is in transport. If either the host bus adapter driver or the target supports queueing, new requests can be submitted while the packet is in transport.
As soon as the SCSI bus is free and the target not busy, the host bus adapter driver selects the target and passes the CDB. The target executes the command and performs the requested data transfers.
After the target sends completion status and the command completes, the host bus adapter driver notifies the target driver by calling the completion function that was specified in the SCSI packet. At this time the host bus adapter driver is no longer responsible for the packet, and the target driver has regained ownership of the packet.
The SCSI packet's completion routine analyzes the returned information and determines whether the SCSI operation was successful. If a failure has occurred, the target driver retries the command by calling scsi_transport(9F) again. If the host bus adapter driver does not support auto request sense, the target driver must submit a request sense packet to retrieve the sense data in the event of a check condition.
If either the command was completed successfully or cannot be retried, the target driver calls scsi_destroy_pkt(9F), which synchronizes the data and frees the packet. If the target driver needs to access the data before freeing the packet, it calls scsi_sync_pkt(9F).
Finally, the target driver notifies the application program that originally requested the read or write that the transaction is complete, either by returning from the read(9E) entry point in the driver (for a character device) or indirectly through biodone(9F).
SCSA allows the execution of many of such operations, both overlapped and queued, at various points in the process. The model places the management of system resources on the host bus adapter driver. The software interface enables the execution of target driver functions on host bus adapter drivers using SCSI bus adapters of varying degrees of sophistication.
SCSA defines functions to manage the allocation and freeing of resources, the sensing and setting of control states, and the transport of SCSI commands. These functions are listed in Table 14–1.
Table 14–1 Standard SCSA Functions
Function Name |
Category |
Resource management |
scsi_dmafree(9F) |
scsi_alloc_consistent_buf(9F) |
scsi_free_consistent_buf(9F) |
Command transport |
Transport information and control |
scsi_ifsetcap(9F) |
scsi_abort(9F) |
Error handling |
scsi_reset(9F) |
scsi_poll(9F) |
Polled I/O |
scsi_probe(9F) |
Probe functions |
scsi_unprobe(9F) |
scsi_setup_cdb(9F) |
CDB initialization function |
If your driver needs to work with a SCSI-1 device, use the makecom(9F) function.
Because SCSI devices are not self-identifying, a hardware configuration file is required for a target driver (see driver.conf(4) and scsi(4) for details). A typical configuration file looks like this:
name="xx" class="scsi" target=2 lun=0;
The system reads the file during autoconfiguration and uses the class property to identify the driver's possible parent. The system then attempts to attach the driver to any parent driver that is of class scsi. All host bus adapter drivers are of this class. Using the class property rather than the parent property enables the target driver to be attached to any host bus adapter driver that finds the expected device at the specified target and lun IDs. The target driver is responsible for verifying this in its probe(9E) routine.
Target drivers must include the header file <sys/scsi/scsi.h>.
SCSI target drivers must use the following command to generate a binary module:
ld -r xx xx.o -N"misc/scsi"
The host bus adapter driver allocates and initializes a scsi_device(9S) structure for the target driver before either the probe(9E) or attach(9E) routine is called. This structure stores information about each SCSI logical unit, including pointers to information areas that contain both generic and device-specific information. There is one scsi_device(9S) structure for each logical unit attached to the system. The target driver can retrieve a pointer to this structure by calling ddi_get_driver_private(9F).
Because the host bus adapter driver uses the private field in the target device's dev_info structure, target drivers must not use ddi_set_driver_private(9F).
The scsi_device(9S) structure contains the following fields:
struct scsi_device { struct scsi_address sd_address; /* opaque address */ dev_info_t *sd_dev; /* device node */ kmutex_t sd_mutex; void *sd_reserved; struct scsi_inquiry *sd_inq; struct scsi_extended_sense *sd_sense; caddr_t sd_private; };
Data structure that is passed to the SCSI resource allocation routines.
Pointer to the target's dev_info structure.
Mutex for use by the target driver. This is initialized by the host bus adapter driver and can be used by the target driver as a per-device mutex. Do not hold this mutex across a call to scsi_transport(9F) or scsi_poll(9F). See Chapter 3, Multithreading for more information on mutexes.
Pointer for the target device's SCSI inquiry data. The scsi_probe(9F) routine allocates a buffer, fills it in with inquiry data, and attaches it to this field.
Pointer to a buffer to contain SCSI request sense data from the device. The target driver must allocate and manage this buffer itself; see attach() Entry Point (SCSI Target Drivers).
Pointer field for use by the target driver. It is commonly used to store a pointer to a private target driver state structure.
The scsi_pkt structure contains the following fields:
struct scsi_pkt { opaque_t pkt_ha_private; /* private data for host adapter */ struct scsi_address pkt_address; /* destination packet is for */ opaque_t pkt_private; /* private data for target driver */ void (*pkt_comp)(struct scsi_pkt *); /* completion routine */ uint_t pkt_flags; /* flags */ int pkt_time; /* time allotted to complete command */ uchar_t *pkt_scbp; /* pointer to status block */ uchar_t *pkt_cdbp; /* pointer to command block */ ssize_t pkt_resid; /* data bytes not transferred */ uint_t pkt_state; /* state of command */ uint_t pkt_statistics; /* statistics */ uchar_t pkt_reason; /* reason completion called */ };
Target device's address set by scsi_init_pkt(9F).
Place to store private data for the target driver. It is commonly used to save the buf(9S) pointer for the command.
Address of the completion routine. The host bus adapter driver calls this routine when it has transported the command. This does not mean that the command succeeded; the target might have been busy or might not have responded before the time-out time elapsed (see the description for pkt_time field). The target driver must supply a valid value in this field, though it can be NULL if the driver does not want to be notified.
There are two different SCSI callback routines. The pkt_comp field identifies a completion callback routine, which is called when the host bus adapter completes its processing. There is also a resource callback routine, called when currently unavailable resources are likely to be available (as in scsi_init_pkt(9F)).
Provides additional control information, for example, to transport the command without disconnect privileges (FLAG_NODISCON) or to disable callbacks (FLAG_NOINTR). See the scsi_pkt(9S) man page for details.
Time-out value (in seconds). If the command is not completed within this time, the host bus adapter calls the completion routine with pkt_reason set to CMD_TIMEOUT. The target driver should set this field to longer than the maximum time the command might take. If the timeout is zero, no timeout is requested. Timeout starts when the command is transmitted on the SCSI bus.
Pointer to the SCSI status completion block; this is filled in by the host bus adapter driver.
Pointer to the SCSI command descriptor block, the actual command to be sent to the target device. The host bus adapter driver does not interpret this field. The target driver must fill it in with a command that the target device can process.
Residual of the operation. When allocating DMA resources for a command scsi_init_pkt(9F), pkt_resid indicates the number of bytes for which DMA resources could not be allocated because of DMA hardware scatter-gather or other device limitations. After command transport, pkt_resid indicates the number of data bytes not transferred; this is filled in by the host bus adapter driver before the completion routine is called.
Indicates the state of the command. The host bus adapter driver fills in this field as the command progresses. One bit is set in this field for each of the five following command states:
STATE_GOT_BUS – Acquired the bus
STATE_GOT_TARGET – Selected the target
STATE_SENT_CMD – Sent the command
STATE_XFERRED_DATA – Transferred data (if appropriate)
STATE_GOT_STATUS – Received status from the device
Contains transport-related statistics set by the host bus adapter driver.
Gives the reason the completion routine was called. The main function of the completion routine is to decode this field and take the appropriate action. If the command completed—in other words, if there were no transport errors—this field is set to CMD_CMPLT; other values in this field indicate an error. After a command is completed, the target driver should examine the pkt_scbp field for a check condition status. See the scsi_pkt(9S) man page for more information.
SCSI target drivers must implement the standard autoconfiguration routines _init(9E), _fini(9E), and _info(9E). See Loadable Driver Interfaces for more information.
probe(9E), attach(9E), detach(9E), and getinfo(9E) are also required, but they must perform SCSI (and SCSA) specific processing.
SCSI target devices are not self-identifying, so target drivers must have a probe(9E) routine. This routine must determine whether the expected type of device is present and responding.
The general structure and return codes of the probe(9E) routine are the same as those of other device drivers. SCSI target drivers must use the scsi_probe(9F) routine in their probe(9E) entry point. scsi_probe(9F) sends a SCSI inquiry command to the device and returns a code indicating the result. If the SCSI inquiry command is successful, scsi_probe(9F) allocates a scsi_inquiry(9S) structure and fills it in with the device's inquiry data. Upon return from scsi_probe(9F), the sd_inq field of the scsi_device(9S) structure points to this scsi_inquiry(9S) structure.
Because probe(9E) must be stateless, the target driver must call scsi_unprobe(9F) before probe(9E) returns, even if scsi_probe(9F) fails.
Example 14–1 shows a typical probe(9E) routine. It retrieves its scsi_device(9S) structure from the private field of its dev_info structure. It also retrieves the device's SCSI target and logical unit numbers so that it can print them in messages. The probe(9E) routine then calls scsi_probe(9F) to verify that the expected device (a printer in this case) is present.
If scsi_probe(9F) succeeds, it has attached the device's SCSI inquiry data in a scsi_inquiry(9S) structure to the sd_inq field of the scsi_device(9S) structure. The driver can then determine if the device type is a printer (reported in the inq_dtype field). If it is, the type is reported with scsi_log(9F), using scsi_dname(9F) to convert the device type into a string.
static int xxprobe(dev_info_t *dip) { struct scsi_device *sdp; int rval, target, lun; /* * Get a pointer to the scsi_device(9S) structure */ sdp = (struct scsi_device *)ddi_get_driver_private(dip); target = sdp->sd_address.a_target; lun = sdp->sd_address.a_lun; /* * Call scsi_probe(9F) to send the Inquiry command. It will * fill in the sd_inq field of the scsi_device structure. */ switch (scsi_probe(sdp, NULL_FUNC)) { case SCSIPROBE_FAILURE: case SCSIPROBE_NORESP: case SCSIPROBE_NOMEM: /* * In these cases, device may be powered off, * in which case we may be able to successfully * probe it at some future time - referred to * as `deferred attach'. */ rval = DDI_PROBE_PARTIAL; break; case SCSIPROBE_NONCCS: default: /* * Device isn't of the type we can deal with, * and/or it will never be usable. */ rval = DDI_PROBE_FAILURE; break; case SCSIPROBE_EXISTS: /* * There is a device at the target/lun address. Check * inq_dtype to make sure that it is the right device * type. See scsi_inquiry(9S)for possible device types. */ switch (sdp->sd_inq->inq_dtype) { case DTYPE_PRINTER: scsi_log(sdp, "xx", SCSI_DEBUG, "found %s device at target%d, lun%d\n", scsi_dname((int)sdp->sd_inq->inq_dtype), target, lun); rval = DDI_PROBE_SUCCESS; break; case DTYPE_NOTPRESENT: default: rval = DDI_PROBE_FAILURE; break; } } scsi_unprobe(sdp); return (rval); }
A more thorough probe(9E) routine could also check other fields of the scsi_inquiry(9S) structure as necessary to make sure that the device is of the type expected by a particular driver.
After the probe(9E) routine has verified that the expected device is present, attach(9E) is called. This routine allocates and initializes any per-instance data, creates minor device node information, and restores the hardware state of a device when the device or the system has been suspended. (See The attach() Entry Point for details.) In addition to these steps, a SCSI target driver again calls scsi_probe(9F) to retrieve the device's inquiry data and also creates a SCSI request sense packet. If the attach is successful, the attach() function should not call scsi_unprobe(9F).
Three routines are used to create the request sense packet: scsi_alloc_consistent_buf(9F), scsi_init_pkt(9F), and scsi_setup_cdb(9F). scsi_alloc_consistent_buf(9F) allocates a buffer suitable for consistent DMA and returns a pointer to a buf(9S) structure. The advantage of a consistent buffer is that no explicit synchronization of the data is required. In other words, the target driver can access the data after the callback. The sd_sense element of the device's scsi_device(9S) structure must be initialized with the address of the sense buffer. scsi_init_pkt(9F) creates and partially initializes a scsi_pkt(9S) structure. scsi_setup_cdb(9F) creates a SCSI command descriptor block, in this case creating a SCSI request sense command.
Note that since a SCSI device is not self-identifying and does not have a reg property, the driver must set the pm-hardware-state property to inform the framework that this device needs to be suspended and resumed.
Example 14–2 shows the SCSI target driver's attach() routine.
static int xxattach(dev_info_t *dip, ddi_attach_cmd_t cmd) { struct xxstate *xsp; struct scsi_pkt *rqpkt = NULL; struct scsi_device *sdp; struct buf *bp = NULL; int instance; instance = ddi_get_instance(dip); switch (cmd) { case DDI_ATTACH: break; case DDI_RESUME: For information, see Chapter 9 default: return (DDI_FAILURE); } allocate a state structure and initialize it ... xsp = ddi_get_soft_state(statep, instance); sdp = (struct scsi_device *)ddi_get_driver_private(dip); /* * Cross-link the state and scsi_device(9S) structures. */ sdp->sd_private = (caddr_t)xsp; xsp->sdp = sdp; call scsi_probe(9F) again to get and validate inquiry data /* * Allocate a request sense buffer. The buf(9S) structure * is set to NULL to tell the routine to allocate a new * one. The callback function is set to NULL_FUNC to tell * the routine to return failure immediately if no * resources are available. */ bp = scsi_alloc_consistent_buf(&sdp->sd_address, NULL, SENSE_LENGTH, B_READ, NULL_FUNC, NULL); if (bp == NULL) goto failed; /* * Create a Request Sense scsi_pkt(9S) structure. */ rqpkt = scsi_init_pkt(&sdp->sd_address, NULL, bp, CDB_GROUP0, 1, 0, PKT_CONSISTENT, NULL_FUNC, NULL); if (rqpkt == NULL) goto failed; /* * scsi_alloc_consistent_buf(9F) returned a buf(9S) structure. * The actual buffer address is in b_un.b_addr. */ sdp->sd_sense = (struct scsi_extended_sense *)bp->b_un.b_addr; /* * Create a Group0 CDB for the Request Sense command */ if (scsi_setup_cdb((union scsi_cdb *)rqpkt->pkt_cdbp, SCMD_REQUEST_SENSE, 0, SENSE__LENGTH, 0) == 0) goto failed;; /* * Fill in the rest of the scsi_pkt structure. * xxcallback() is the private command completion routine. */ rqpkt->pkt_comp = xxcallback; rqpkt->pkt_time = 30; /* 30 second command timeout */ rqpkt->pkt_flags |= FLAG_SENSING; xsp->rqs = rqpkt; xsp->rqsbuf = bp; create minor nodes, report device, and do any other initialization /* * Since the device does not have the 'reg' property, * cpr will not call its DDI_SUSPEND/DDI_RESUME entries. * The following code is to tell cpr that this device * needs to be suspended and resumed. */ (void) ddi_prop_update_string(device, dip, "pm-hardware-state", "needs-suspend-resume"); xsp->open = 0; return (DDI_SUCCESS); failed: if (bp) scsi_free_consistent_buf(bp); if (rqpkt) scsi_destroy_pkt(rqpkt); sdp->sd_private = (caddr_t)NULL; sdp->sd_sense = NULL; scsi_unprobe(sdp); free any other resources, such as the state structure return (DDI_FAILURE); }
The detach(9E) entry point is the inverse of attach(9E); it must free all resources that were allocated in attach(). If successful, the detach should call scsi_unprobe(9F). Example 14–3 shows a target driver detach() routine.
static int xxdetach(dev_info_t *dip, ddi_detach_cmd_t cmd) { struct xxstate *xsp; switch (cmd) { case DDI_DETACH: normal detach(9E) operations, such as getting a pointer to the state structure ... scsi_free_consistent_buf(xsp->rqsbuf); scsi_destroy_pkt(xsp->rqs); xsp->sdp->sd_private = (caddr_t)NULL; xsp->sdp->sd_sense = NULL; scsi_unprobe(xsp->sdp); remove minor nodes free resources, such as the state structure and properties return (DDI_SUCCESS); case DDI_SUSPEND: For information, see Chapter 9 default: return (DDI_FAILURE); } }
The getinfo(9E) routine for SCSI target drivers is much the same as for other drivers (see The getinfo() Entry Point for more information on DDI_INFO_DEVT2INSTANCE case). However, in the DDI_INFO_DEVT2DEVINFO case of the getinfo() routine, the target driver must return a pointer to its dev_info node. This pointer can be saved in the driver state structure or can be retrieved from the sd_dev field of the scsi_device(9S) structure. Example 14–4shows an alternative SCSI target driver getinfo() code fragment.
... case DDI_INFO_DEVT2DEVINFO: dev = (dev_t)arg; instance = getminor(dev); xsp = ddi_get_soft_state(statep, instance); if (xsp == NULL) return (DDI_FAILURE); *result = (void *)xsp->sdp->sd_dev; return (DDI_SUCCESS); ...
To send a SCSI command to the device, the target driver must create and initialize a scsi_pkt(9S) structure and pass it to the host bus adapter driver.
The scsi_init_pkt(9F) routine allocates and zeros a scsi_pkt(9S) structure; it also sets pointers to pkt_private, *pkt_scbp, and *pkt_cdbp. Additionally, it provides a callback mechanism to handle the case where resources are not available. This function has the following syntax:
struct scsi_pkt *scsi_init_pkt(struct scsi_address *ap, struct scsi_pkt *pktp, struct buf *bp, int cmdlen, int statuslen, int privatelen, int flags, int (*callback)(caddr_t), caddr_t arg)
Pointer to a scsi_address structure. This is the sd_address field of the device's scsi_device(9S) structure.
Pointer to the scsi_pkt(9S) structure to be initialized. If this is set to NULL, a new packet is allocated.
Pointer to a buf(9S) structure. If this is non-NULL and contains a valid byte count, DMA resources are allocated.
Length of the SCSI command descriptor block in bytes.
Required length of the SCSI status completion block in bytes.
Number of bytes to allocate for the pkt_private field.
Set of flags. Possible bits include:
PKT_CONSISTENT – This bit must be set if the DMA buffer was allocated using scsi_alloc_consistent_buf(9F). In this case, the host bus adapter driver guarantees that the data transfer is properly synchronized before performing the target driver's command completion callback.
PKT_DMA_PARTIAL – This bit can be set if the driver accepts a partial DMA mapping. If set, scsi_init_pkt(9F) allocates DMA resources with the DDI_DMA_PARTIAL flag set. The pkt_resid field of the scsi_pkt(9S) structure can be returned with a nonzero residual, indicating the number of bytes for which scsi_init_pkt(9F) was unable to allocate DMA resources.
Specifies the action to take if resources are not available. If set to NULL_FUNC, scsi_init_pkt(9F) returns immediately (returning NULL). If set to SLEEP_FUNC, it does not return until resources are available. Any other valid kernel address is interpreted as the address of a function to be called when resources are likely to be available.
Parameter to pass to the callback function.
The scsi_init_pkt() routine synchronizes the data prior to transport. If the driver needs to access the data after transport, it should call scsi_sync_pkt(9F) to flush any intermediate caches. The scsi_sync_pkt() routine can be used to synchronize any cached data.
If the target driver needs to resubmit the packet after changing the data, scsi_sync_pkt(9F) must be called before calling scsi_transport(9F). However, if the target driver does not need to access the data, there is no need to call scsi_sync_pkt() after the transport.
The scsi_destroy_pkt(9F) routine synchronizes any remaining cached data associated with the packet, if necessary, and then frees the packet and associated command, status, and target driver-private data areas. This routine should be called in the command completion routine.
For most I/O requests, the data buffer passed to the driver entry points is not accessed directly by the driver; it is just passed on to scsi_init_pkt(9F). If a driver sends SCSI commands that operate on buffers that the driver itself examines (such as the SCSI request sense command), the buffers should be DMA consistent. The scsi_alloc_consistent_buf(9F) routine allocates a buf(9S) structure and a data buffer suitable for DMA-consistent operations. The HBA will perform any necessary synchronization of the buffer before performing the command completion callback.
scsi_alloc_consistent_buf(9F) uses scarce system resources; use it sparingly.
scsi_free_consistent_buf(9F) releases a buf(9S) structure and the associated data buffer allocated with scsi_alloc_consistent_buf(9F). See attach() Entry Point (SCSI Target Drivers) and detach() Entry Point (SCSI Target Drivers) for examples.
The host bus adapter driver is responsible for transmitting the command to the device and handling the low-level SCSI protocol. The scsi_transport(9F) routine hands a packet to the host bus adapter driver for transmission. The target driver has the responsibility to create a valid scsi_pkt(9S) structure.
The routine scsi_init_pkt(9F) allocates space for a SCSI CDB, allocates DMA resources if necessary, and sets the pkt_flags field, as shown in this example:
pkt = scsi_init_pkt(&sdp->sd_address, NULL, bp, CDB_GROUP0, 1, 0, 0, SLEEP_FUNC, NULL);
This example creates a new packet and allocates DMA resources as specified in the passed buf(9S) structure pointer. A SCSI CDB is allocated for a Group 0 (6-byte) command, the pkt_flags field is set to zero, but no space is allocated for the pkt_private field. This call to scsi_init_pkt(9F), because of the SLEEP_FUNC parameter, waits indefinitely for resources if none are currently available.
The next step is to initialize the SCSI CDB, using the scsi_setup_cdb(9F) function:
if (scsi_setup_cdb((union scsi_cdb *)pkt->pkt_cdbp, SCMD_READ, bp->b_blkno, bp->b_bcount >> DEV_BSHIFT, 0) == 0) goto failed;
This example builds a Group 0 command descriptor block and fills in the pkt_cdbp field as follows:
The command itself (byte 0) is set from the parameter (SCMD_READ).
The address field (bits 0-4 of byte 1 and bytes 2 and 3) is set from bp->b_blkno.
The count field (byte 4) is set from the last parameter. In this case it is set to bp->b_bcount >> DEV_BSHIFT, where DEV_BSHIFT is the byte count of the transfer converted to the number of blocks.
scsi_setup_cdb(9F) does not support setting a target device's logical unit number (LUN) in bits 5-7 of byte 1 of the SCSI command block, as defined by SCSI-1. For SCSI-1 devices requiring the LUN bits set in the command block, use makecom_g0(9F) (or equivalent) rather than scsi_setup_cdb(9F).
After initializing the SCSI CDB, initialize three other fields in the packet and store as a pointer to the packet in the state structure.
pkt->pkt_private = (opaque_t)bp; pkt->pkt_comp = xxcallback; pkt->pkt_time = 30; xsp->pkt = pkt;
The buf(9S) pointer is saved in the pkt_private field for later use in the completion routine.
The target drivers use scsi_ifsetcap(9F) to set the capabilities of the host adapter driver. A cap is a name-value pair whose name is a null terminated character string and whose value is an integer. The current value of a capability can be retrieved using scsi_ifgetcap(9F). scsi_ifsetcap(9F) allows capabilities to be set for all targets on the bus.
In general, however, setting capabilities of targets that are not owned by the target driver is not recommended and is not universally supported by HBA drivers. Some capabilities (such as disconnect and synchronous) can be set by default by the HBA driver but others might need to be set explicitly by the target driver (wide-xfer or tagged-queueing, for example).
After creating and filling in the scsi_pkt(9S) structure, the final step is to hand it to the host bus adapter driver using scsi_transport(9F):
if (scsi_transport(pkt) != TRAN_ACCEPT) { bp->b_resid = bp->b_bcount; bioerror(bp, EIO); biodone(bp); }
The other return values from scsi_transport(9F) are:
TRAN_BUSY – There is already a command in progress for the specified target.
TRAN_BADPKT – The DMA count in the packet was too large, or the host adapter driver rejected this packet for other reasons.
TRAN_FATAL_ERROR – The host adapter driver is unable to accept this packet.
The mutex sd_mutex in the scsi_device(9S) structure must not be held across a call to scsi_transport(9F).
If scsi_transport(9F) returns TRAN_ACCEPT, the packet is the responsibility of the host bus adapter driver and should not be accessed by the target driver until the command completion routine is called.
If FLAG_NOINTR is set in the packet, then scsi_transport(9F) will not return until the command is complete, and no callback will be performed.
Do not use FLAG_NOINTR in interrupt context.
Once the host bus adapter driver has done all it can with the command, it invokes the packet's completion callback routine, passing a pointer to the scsi_pkt(9S) structure as a parameter. The completion routine decodes the packet and takes the appropriate action.
Example 14–5 presents a simple completion callback routine. This code checks for transport failures and gives up rather than retrying the command. If the target is busy, extra code is required to resubmit the command at a later time.
If the command results in a check condition, the target driver needs to send a request sense command unless auto request sense has been enabled.
Otherwise, the command succeeded. If this is the end of processing for the command, it destroys the packet and calls biodone(9F).
In the event of a transport error (such as a bus reset or parity problem), the target driver can resubmit the packet using scsi_transport(9F). There is no need to change any values in the packet prior to resubmitting.
Example 14–5 does not attempt to retry incomplete commands.
Normally, the target driver's callback function is called in interrupt context. Consequently, the callback function should never sleep.
static void xxcallback(struct scsi_pkt *pkt) { struct buf *bp; struct xxstate *xsp; minor_t instance; struct scsi_status *ssp; /* * Get a pointer to the buf(9S) structure for the command * and to the per-instance data structure. */ bp = (struct buf *)pkt->pkt_private; instance = getminor(bp->b_edev); xsp = ddi_get_soft_state(statep, instance); /* * Figure out why this callback routine was called */ if (pkt->pkt_reason != CMP_CMPLT) { bp->b_resid = bp->b_bcount; bioerror(bp, EIO); scsi_destroy_pkt(pkt); /* release resources */ biodone(bp); /* notify waiting threads */ ; } else { /* * Command completed, check status. * See scsi_status(9S) */ ssp = (struct scsi_status *)pkt->pkt_scbp; if (ssp->sts_busy) { error, target busy or reserved } else if (ssp->sts_chk) { send a request sense command } else { bp->b_resid = pkt->pkt_resid; /*packet completed OK */ scsi_destroy_pkt(pkt); biodone(bp); } } }
A target driver can reuse packets in the following ways:
Resubmit the packet unchanged.
Use scsi_sync_pkt(9F) to synchronize the data, then process the data in the driver and resubmit.
Free DMA resources, using scsi_dmafree(9F), and pass the pkt pointer to scsi_init_pkt(9F) for binding to a new bp. The target driver is responsible for reinitializing the packet. The CDB has to have the same length as the previous CDB.
If partial DMA was allocated during the first call to scsi_init_pkt(9F), subsequent calls to scsi_init_pkt(9F) can be made for the same packet and bp to adjust the DMA resources to the next portion of the transfer.
Auto-request sense mode is most desirable if tagged or untagged queuing is used. A contingent allegiance condition is cleared by any subsequent command and, consequently, the sense data is lost. Most HBA drivers will start the next command before performing the target driver callback. Other HBA drivers can use a separate and lower-priority thread to perform the callbacks, which might increase the time needed to notify the target driver that the packet completed with a check condition. In this case, the target driver might not be able to submit a request sense command in time to retrieve the sense data.
To avoid this loss of sense data, the HBA driver, or controller, should issue a request sense command as soon as a check condition has been detected; this mode is known as auto-request sense mode. Note that not all HBA drivers are capable of auto-request sense mode, and some can only operate with auto-request sense mode enabled.
A target driver enables auto-request-sense mode by using scsi_ifsetcap(9F). Example 14–6 shows enabling auto request sense.
static int xxattach(dev_info_t *dip, ddi_attach_cmd_t cmd) { struct xxstate *xsp; struct scsi_device *sdp = (struct scsi_device *) ddi_get_driver_private(dip); ... /* * enable auto-request-sense; an auto-request-sense cmd may * fail due to a BUSY condition or transport error. Therefore, * it is recommended to allocate a separate request sense * packet as well. * Note that scsi_ifsetcap(9F) may return -1, 0, or 1 */ xsp->sdp_arq_enabled = ((scsi_ifsetcap(ROUTE, “auto-rqsense”, 1, 1) == 1) ? 1 : 0); /* * if the HBA driver supports auto request sense then the * status blocks should be sizeof (struct scsi_arq_status); else * one byte is sufficient */ xsp->sdp_cmd_stat_size = (xsp->sdp_arq_enabled ? sizeof (struct scsi_arq_status) : 1); ... }
When a packet is allocated using scsi_init_pkt(9F) and auto request sense is desired on this packet, then the target driver must request additional space for the status block to hold the auto request sense structure. The sense length used in the request sense command is sizeof (struct scsi_extended_sense). Auto request sense can be disabled per individual packet by just allocating sizeof (struct scsi_status) for the status block.
The packet is submitted using scsi_transport(9F) as usual. When a check condition occurs on this packet, the host adapter driver takes the following steps:
Issues a request sense command if the controller doesn't have auto-request-sense capability
Obtains the sense data
Fills in the scsi_arq_status information in the packet's status block
Sets STATE_ARQ_DONE in the packet's pkt_state field
Calls the packet's callback handler (pkt_comp())
The target driver's callback routine should verify that sense data is available by checking the STATE_ARQ_DONE bit in pkt_state, which implies that a check condition has occurred and a request sense has been performed. If auto-request-sense has been temporarily disabled in a packet, there is no guarantee that the sense data can be retrieved at a later time.
The target driver should then verify whether the auto request sense command completed successfully and decode the sense data.
The dump(9E) entry point is used to copy a portion of virtual address space directly to the specified device in the case of system failure or checkpoint operation. See the cpr(7) and dump(9E) man pages. The dump(9E) entry point must be capable of performing this operation without the use of interrupts.
The arguments for dump() are as follows. dev is the device number of the dump device, addr is the kernel virtual address at which to start the dump, blkno is the first destination block on the device, and nblk is the number of blocks to dump.
static int xxdump(dev_t dev, caddr_t addr, daddr_t blkno, int nblk) { struct xxstate *xsp; struct buf *bp; struct scsi_pkt *pkt; int rval; int instance; instance = getminor(dev); xsp = ddi_get_soft_state(statep, instance); if (tgt->suspended) { (void) ddi_dev_is_needed(DEVINFO(tgt), 0, 1); } bp = getrbuf(KM_NOSLEEP); if (bp == NULL) { return (EIO); } Calculate block number relative to partition bp->b_un.b_addr = addr; bp->b_edev = dev; bp->b_bcount = nblk * DEV_BSIZE; bp->b_flags = B_WRITE | B_BUSY; bp->b_blkno = blkno; pkt = scsi_init_pkt(ROUTE(tgt), NULL, bp, CDB_GROUP1, sizeof (struct scsi_arq_status), sizeof (struct bst_pkt_private), 0, NULL_FUNC, NULL); if (pkt == NULL) { freerbuf(bp); return (EIO); } (void) scsi_setup_cdb((union scsi_cdb *)pkt->pkt_cdbp, SCMD_WRITE_G1, blkno, nblk, 0); /* * while dumping in polled mode, other cmds might complete * and these should not be resubmitted. we set the * dumping flag here which prevents requeueing cmds. */ tgt->dumping = 1; rval = scsi_poll(pkt); tgt->dumping = 0; scsi_destroy_pkt(pkt); freerbuf(bp); if (rval != DDI_SUCCESS) { rval = EIO; } return (rval); }
SCSA defines a global variable, scsi_options, which can be used for debug and control. The defined bits in scsi_options can be found in the file <sys/scsi/conf/autoconf.h>. The following table describes the use of these bits.
Table 14–2 SCSA Options
Option |
Description |
SCSI_OPTIONS_DR |
Enables global disconnect/reconnect |
SCSI_OPTIONS_SYNC |
Enables global synchronous transfer capability |
SCSI_OPTIONS_LINK |
Enables global link support |
SCSI_OPTIONS_PARITY |
Enables global parity support |
SCSI_OPTIONS_TAG |
Enables global tagged queuing support |
SCSI_OPTIONS_FAST |
Enables global FAST SCSI support: 10 Mbytes/sec transfers, as opposed to 5 Mbytes/sec |
SCSI_OPTIONS_FAST20 |
Enables global FAST20 SCSI support: 20 Mbytes/sec transfers |
SCSI_OPTIONS_FAST40 |
Enables global FAST40 SCSI support: 40 Mbytes/sec transfers |
SCSI_OPTIONS_FAST80 |
Enables global FAST80 SCSI support: 80 Mbytes/sec transfers |
SCSI_OPTIONS_WIDE |
Enables global WIDE SCSI |
The setting of scsi_options affects all host adapter and target drivers present on the system (as opposed to scsi_ifsetcap(9F). Refer to the scsi_hba_attach(9F) man page for information on controlling these options for a particular host adapter.
