To support the minimal set of hot-plugging operations, drivers might need to implement support for bus quiesce, bus unquiesce, and bus reset. The scsi_hba_tran(9S) structure supports these operations. If quiesce/unquiesce/reset is not required by hardware, no driver changes are needed.
The scsi_hba_tran structure includes the following fields:
int (*tran_quiesce)(dev_info_t *hba_dip);
int (*tran_unquiesce)(dev_info_t *hba_dip);
int (*tran_bus_reset)(dev_info_t *hba_dip, int level);
These interfaces quiesce and unquiesce a SCSI bus.
#include <sys/scsi/scsi.h>
int prefixtran_quiesce(dev_info_t *hba_dip);
int prefixtran_unquiesce(dev_info_t *hba_dip);
tran_quiesce(9E) and tran_unquiesce(9E) must be implemented by an HBA driver to support dynamic reconfiguration (DR) of SCSI devices on buses that were not designed to support hot-plugging.
The tran_quiesce(9E) and tran_unquiesce(9E) vectors in the scsi_hba_tran(9S) structure should be initialized during the HBA driver's attach(9E) to point to HBA entry points so they are called when a user initiates quiesce and unquiesce operations.
tran_quiesce(9E) is called by the SCSA framework to stop all activity on a SCSI bus prior to and during the reconfiguration of devices attached to the SCSI bus. tran_unquiesce(9E) is called by the SCSA framework to resume activity on the SCSI bus after the reconfiguration operation has been completed.
HBA drivers are required to handle tran_quiesce(9E) by waiting for all outstanding commands to complete before returning success. After the HBA has quiesced the bus, it must queue any new I/O requests from target drivers until the SCSA framework calls the corresponding tran_unquiesce(9E) entry point.
HBA drivers handle calls to tran_unquiesce(9E) by starting any target driver I/O requests that were queued by the HBA during the time the bus was quiesced.
