CDE provides the ability to enter localized input for an internationalized application using Xm Toolkit. The XmText[Field] widgets are enabled to interface with input methods from each locale. Input methods are internationalized because some language environments write their text from right-to-left, top-to-bottom, and so forth. Within the same application, you can use different input methods that apply several fonts.
The pre-edit area displays the string that is being pre-edited. This can be done in four modes:
OffTheSpot
OverTheSpot (default)
Root
None
In OffTheSpot mode, the location is just below the Main Window area at the right of the status area. In OverTheSpot mode, the pre-edit area is at the cursor point. In Root mode, the pre-edit and status areas are separate from the client's window.
For more details, refer to the XmNpreeditType resource description on the VendorShell(3X) man page.
In the Solaris 9 environment, native Asian input methods exist for Simplified/Traditional Chinese, Japanese, and Korean. These methods are in addition to the current multiscript input methods for Unicode locales.
The following discussion includes descriptions of selected input methods, how to use them, and how to switch between them.
Solaris Unicode locales support multiple scripts. Every Unicode locale has a total of fourteen input modes:
English/European
Cyrillic
Greek
Arabic
Hebrew
Thai
Japanese
Korean
Simplified Chinese
Traditional Chinese
Traditional Chinese (Hong Kong)
Hindi
Unicode Hexadecimal and Octal code input methods
Table lookup input method
You can switch into a particular input mode by using a Compose key combination or through the input mode selection window. To access the input mode selection window, press mouse button 1 in the status area at the bottom left corner of your application window. The input mode selection window is shown in following figure.
You can change the current input mode to a new input mode by using the key sequences listed in Table 5–1. The only restriction for using these key sequences is that if you are in one of the Asian input modes, you need to switch back to English/European input mode by pressing Control and spacebar together. Once you are in the English/European input mode, you can switch freely to any other input mode by using the key sequences.
The following key sequences show how to switch to Cyrillic from the English/European input mode:
Press the Compose key.
Press and release c.
Press c.
Key Sequences |
Input Mode |
Control + Spacebar |
English/European |
Compose c c |
Cyrillic |
Compose g g |
Greek |
Compose a r |
Arabic |
Compose h h |
Hebrew |
Compose t t |
Thai |
Compose h i |
Hindi |
Compose j a |
Japanese |
Compose k o |
Korean |
Compose s c |
Simplified Chinese |
Compose t c |
Traditional Chinese |
Compose h k |
Traditional Chinese (Hong Kong) |
Compose u o |
Unicode octal code input method |
Compose u h |
Unicode hexadecimal code input method |
Compose l l |
Table lookup input method |
The English/European input mode includes the English alphabet plus characters with diacritical marks (for example, á, è, î, õ, and ü) and characters (such as ¡, §, ¿) from European scripts.
This input mode is the default mode for any application. The input mode is displayed at the bottom left corner of the GUI application window.
To insert characters with diacritical marks or special characters from Latin-1, Latin-2, Latin-4, Latin-5, and Latin-9, you must type a Compose key sequence, as described in the following examples.
To display the Ä character:
Press and release the Compose key.
Press Shift and A simultaneously. Release Shift and A.
Press and release ".
To display the ¿, character:
Press and release ?.
When there is no Compose key available on your keyboard, you can emulate its operation by simultaneously pressing the Control key and the Shift key.
For the input of the Euro currency symbol (Unicode value U+20AC) from the locale, you can use any one of following input sequences:
AltGraph and E together
AltGraph and 4 together
AltGraph and 5 together
With these input sequences, you press both keys simultaneously. If there is no AltGraph key available on your keyboard, you can substitute the Alt key.
The following tables show the most commonly used compose sequences for Latin-1, Latin-2, Latin-3, Latin-4, Latin-5, and Latin-9 script input for the Solaris operating environment.
The following table lists the common Latin-1 Compose key sequences.
Table 5–2 Common Latin-1 Compose Key Sequences|
Press Compose, then Press and Release |
Then Press and Release |
Result |
spacebar |
spacebar |
no-break space |
s |
1 |
superscripted 1 |
s |
2 |
superscripted 2 |
s |
3 |
superscripted 3 |
inverted exclamation mark |
x |
o |
currency symbol ¤ |
p |
paragraph symbol ¶ |
u |
mu u |
acute accent ´ |
, (comma) |
cedilla Ç |
diaeresis ¨ |
macron ¯ |
o |
o |
degree ° |
x |
x |
multiplication sign x |
plus-minus ± |
soft hyphen – |
division sign ÷ |
a |
ordinal (feminine) ª |
o |
ordinal (masculine) º |
, (comma) |
not sign ¬ |
middle dot · |
1 |
2 |
vulgar fraction ½ |
1 |
4 |
vulgar fraction ¼ |
3 |
4 |
vulgar fraction ¾ |
left double angle quotation mark « |
right double angle quotation mark » |
inverted question mark ¿ |
A |
` (backquote) |
A grave À |
A |
' (single quote) |
A acute Á |
A |
A ring above Å |
A |
A diaeresis Ä |
A |
A circumflex  |
A |
A tilde à |
A |
E |
AE diphthong Æ |
C |
, (comma) |
C cedilla Ç |
C |
o |
copyright sign © |
D |
Capital eth ð |
E |
` (backquote) |
E grave È |
E |
E acute É |
E |
E diaeresis Ë |
E |
E circumflex Ê |
I |
` (backquote) |
I grave Ì |
I |
I acute Í |
I |
I diaeresis Ï |
I |
I circumflex Î |
L |
pound sign £ |
N |
N tilde Ñ |
O |
` (backquote) |
O grave Ò |
O |
O acute Ó |
O |
O slash Ø |
O |
O diaeresis Ö |
O |
O circumflex Ô |
O |
O tilde Õ |
R |
O |
registered mark ® |
T |
H |
Thorn þ |
U |
` (backquote) |
U grave Ù |
U |
U acute Ú |
U |
U diaeresis Ü |
U |
U circumflex Û |
Y |
Y acute ý |
Y |
yen sign ¥ |
a |
` (backquote) |
a grave à |
a |
a acute á |
a |
a ring above å |
a |
a diaeresis ä |
a |
a tilde ã |
a |
a circumflex â |
a |
e |
ae diphthong æ |
c |
, (comma) |
c cedilla ç |
c |
cent sign ¢ |
c |
o |
copyright sign © |
d |
eth ð |
e |
` (backquote) |
e grave è |
e |
e acute é |
e |
e diaeresis ë |
e |
e circumflex ê |
i |
` (backquote) |
i grave ì |
i |
i acute í |
i |
i diaeresis ï |
i |
i circumflex î |
n |
n tilde ñ |
o |
` (backquote) |
o grave ò |
o |
o acute ó |
o |
o slash ø |
o |
o diaeresis ö |
o |
o circumflex ô |
o |
o tilde õ |
s |
s |
German double s ß also known as sharp S |
t |
h |
thorn þ |
u |
` (backquote) |
u grave ù |
u |
u acute ú |
u |
u diaeresis ü |
u |
u circumflex û |
y |
y acute y |
y |
y diaeresis ÿ |
The following table lists the common Latin-2 and Latin-4 Compose key sequences.
Table 5–3 Common Latin-2 Compose Key Sequences|
Press and Release |
Result |
a |
spacebar |
ogonek |
u |
spacebar |
breve |
v |
spacebar |
caron |
spacebar |
double acute |
A |
a |
A ogonek |
A |
u |
A breve |
C |
C acute |
C |
v |
C caron |
D |
v |
D caron |
D |
D stroke |
E |
v |
E caron |
E |
a |
E ogonek |
L |
L acute |
L |
L stroke |
L |
L caron |
N |
N acute |
N |
v |
N caron |
O |
O double acute |
S |
S acute |
S |
v |
S caron |
S |
S cedilla |
R |
R acute |
R |
v |
R caron |
T |
v |
T caron |
T |
T cedilla |
U |
U ring above |
U |
U double acute |
Z |
Z acute |
Z |
v |
Z caron |
Z |
Z dot above |
k |
k |
kra |
A |
_ |
A macron |
E |
_ |
E macron |
E |
E dot above |
G |
G cedilla |
I |
_ |
I macron |
I |
I tilde |
I |
a |
I ogonek |
K |
K cedilla |
L |
L cedilla |
N |
N cedilla |
O |
_ |
O macron |
R |
R cedilla |
T |
T stroke |
U |
U tilde |
U |
a |
U ogonek |
U |
_ |
U macron |
N |
N |
Eng |
a |
_ |
a macron |
e |
_ |
e macron |
e |
e dot above |
g |
g cedilla |
i |
_ |
i macron |
i |
i tilde |
i |
a |
i ogonek |
k |
k cedilla |
l |
l cedilla |
n |
n cedilla |
o |
_ |
o macron |
r |
r cedilla |
t |
t stroke |
u |
u tilde |
u |
a |
u ogonek |
u |
_ |
u macron |
n |
n | |
The following table lists the common Latin-3 Compose key sequences.
Table 5–4 Common Latin-3 Compose Key Sequences|
Press and Release |
Result |
C |
C circumflex |
C |
C dot above |
G |
G circumflex |
G |
G dot above |
H |
H circumflex |
J |
j circumflex |
S |
S circumflex |
U |
u |
U breve |
c |
c circumflex |
c |
c dot above |
g |
g circumflex |
g |
g dot above |
h |
h circumflex |
j |
j circumflex |
s |
s circumflex |
u |
u |
u breve |
The following table lists the common Latin-5 Compose key sequences.
Table 5–5 Common Latin-5 Compose Key Sequences|
Press and Release |
Result |
G |
u |
G breve |
I |
I dot above |
g |
u |
g breve |
i |
The following table lists the Common Latin-9 Compose key sequences.
Table 5–6 Common Latin-9 Compose Key Sequences|
Press and Release |
Result |
o |
e |
Ligature oe |
O |
E |
Ligature OE |
Y |
Y diaeresis |
To switch to Arabic input mode, either type Compose a r, or select Arabic from the input mode selection window. For information on accessing the input mode selection window, see Figure 5–1.
The following figure shows the Arabic keyboard layout.
To switch to Cyrillic input mode, either press Compose c c, or select Cyrillic from the Input Mode Selection Window. For information on accessing the input mode selection window, see Figure 5–1.
The Cyrillic (Russian) keyboard layout appears in the following figure.
After you switch to Cyrillic input mode, you cannot enter English or European text. To switch back to the English/European input mode, type Control and spacebar together, or select English/European input mode from the Input Mode Selection Window by clicking in the status area. See Figure 5–1.
You can also switch into other input modes by typing the corresponding input mode switch key sequence.
To switch to Greek input mode, either press Compose g g, or select Greek, from the input mode selection window. For information on accessing the input mode selection window, see Figure 5–1.
After you switch to Greek input mode, you cannot enter English or European text. To switch back to the English/European input mode, type Control and spacebar together, or select English/European input mode from the Input Mode Selection Window by clicking in the status area. The Greek Euro keyboard layout appears in the following figure.
The following figure shows the Greek UNIX keyboard.
To switch into Hebrew input mode, either press Compose h h, or select Hebrew from the input mode selection window. For information on accessing the input mode selection window, see Figure 5–1.
The following figure shows the Hebrew keyboard layout.
To switch to Hindi input mode, either press Compose h i, or select Hindi from the input mode selection window. For more information on accessing the input mode selection window, see Figure 5–1. To switch back to English/European input mode type Control and spacebar together, or select English/European input mode from the input mode selection window by clicking in the status area.
The keyboard for Hindi-Shift is shown in the following figure.
To switch to Japanese input mode, either press Compose j a, or select Japanese from the input mode selection window. For information on accessing the input mode selection window, see Figure 5–1.
To use the native Japanese input system, you need to install one or more of the Japanese locales and reboot the system. After you install the Japanese locale, you can use ATOK12 in all UTF-8 locales. Wnn6 is not available in UTF-8 locales except ja_JP.UTF-8.
To switch to Korean input mode, either press Compose k o, or select Korean from the input mode selection window. For information on accessing the input mode selection window, see Figure 5–1.
To have the native Korean input system, you need to install one or more Korean locales on your system. Once you install the Korean locale, you can use the native Korean input system. For more details on how to use the Korean Input System, refer to Korean Solaris User's Guide.
To switch to Simplified Chinese input mode, either press Compose s c, or select S-Chinese from the input mode selection window. For information on accessing the input mode selection window, see Figure 5–1.
To use the native Simplified Chinese input system, you need to install one or more Simplified Chinese locales on your system. For more details on how to use Simplified Chinese Input System, refer to Simplified Chinese Solaris User's Guide.
To switch to Thai input mode, either press Compose t t, or select Thai, from the input mode selection window. For information on accessing the input mode selection window, see Figure 5–1.
The Thai keyboard layout is shown in the following figure.
To switch to Traditional Chinese input mode, either press Compose t c, or select T-Chinese from the input mode selection window. For information on accessing the input mode selection window, see Figure 5–1.
To have access to the native Traditional Chinese input system, you need to install one or more Traditional Chinese locales at your system. For more details on how to use the Traditional Chinese Input System, refer to Traditional Chinese Solaris User's Guide.
To switch to Traditional Chinese input mode, either press Compose h k, or select T-Chinese (Hong Kong) from the input mode selection window. For information on accessing the input mode selection window, see Figure 5–1.
To have access to the native Traditional Chinese (Hong Kong) input system, you need to install one or more Traditional Chinese (Hong Kong) locales on your system.
To switch to Unicode hexadecimal code input method input mode, either press Compose u h, or select Unicode Hex from the input mode selection window. To switch to the octal number system, press Compose u o or select Unicode Octal. For information on accessing the input mode selection window, see Figure 5–1.
To use these input modes, you need to know either the hexadecimal or the octal code point values of the characters. Refer to The Unicode Standard, Version 3.0 for the mapping between code point values and characters.
If you are in the Unicode hexadecimal code input mode, to input a character you would type four hexadecimal digits. Some sample hexadecimal values are:
00A1 for Inverted Exclamation Mark
03B2 for Greek Small Letter Beta
AC00 for a Korean Hangul Syllable
30A1 for Japanese Katakana Letter A
4E58 for a Unified Han character
You can use both uppercase and lowercase letters of A, B, C, D, E, and, F for hexadecimal digits. If you prefer the octal number system instead of hexadecimal numbers, you can input octal digits, 0 to 7. If you mistype a digit or two, you can delete the digits by using the Delete or Backspace key.
To switch to table lookup input mode, either press Compose l l, or select Lookup from the input mode selection window. For information on accessing the input mode selection window, see Figure 5–1.
The second lookup window shows candidates for the group only display, 80 candidates at a time maximum. Press Control n for the next set of candidates or Control p for previous set of candidates.
