Solaris WBEM SDK Developer's Guide
WHERE Clause
The WHERE clause narrows the scope of a query. This clause contains a conditional expression, which can contain a property or key word, an operator, and a constant.
The syntax for a WHERE clause appended to a SELECT statement is as follows:
SELECT CIMinstance FROM CIMclass WHERE conditional_expression
The conditional_expression in the WHERE clause takes the following form:
property operator constant
The expression is composed of a property or key word, an operator, and a constant. You can append the WHERE clause to the SELECT statement using one of the following forms:
SELECT instance FROM class [[WHERE constant operator property]]
Valid WHERE clauses follow these rules:
Standard WQL Operators for WHERE Clauses
You can use the following standard WQL operators for a binary expression in the WHERE clause of a SELECT statement.
Table 5-4 WQL Operators for WHERE Clauses
Operator
Description
Equal to
Less than
Greater than
Less than or equal to
Greater than or equal to
Not equal to
