Event filters describe the types of events to be delivered and the conditions under which they are delivered. To create an event filter, create an instance of the CIM_IndicationFilter class and define values for its properties. Each event filter works only on events that belong to the namespace to which the filter belongs.
The CIM_IndicationFilter class has string properties that you can set to uniquely identify the filter, specify a query string, and specify the query language that parses the query string. Currently, only the WBEM Query Language (WQL) is supported.
Table 3-6 CIM_IndicationFilter Properties|
Property |
Description |
Required/Optional |
SystemCreationClassName |
The name of the system on which the creation class for the filter resides or to which it applies. |
Optional. The value is decided by the CIM Object Manager. |
SystemName |
The name of the system on which the filter resides or to which it applies. |
Optional. The default for this key property is the name of the system on which the CIM Object Manager is running. |
CreationClassName |
The name of the class or subclass used to create the filter. |
Optional. The CIM Object Manager assigns CIM_IndicationFilter as the default for this key property. |
Name |
The unique name of the filter. |
Optional. The CIM Object Manager assigns a unique name. |
SourceNamespace |
The path to a local namespace where the CIM indications originate. |
Optional. The default is null. |
Query |
A query expression that defines the conditions under which indications are generated. Currently, only Level 1 WBEM Query Language (WQL) expressions are supported. To learn more about WQL query expressions, see Chapter 5, Writing WBEM Queries. |
Required. |
QueryLanguage |
The language in which the query is expressed. |
Required. The default is WQL (WBEM Query Language). |
Create an instance of the CIM_IndicationFilter class:
CIMClass cimfilter = cc.getClass
(new CIMObjectPath(“CIM_IndicationFilter”),
true, true, true, null);
CIMInstance ci = cimfilter.newInstance();
Specify the name of the event filter:
Name = “filter_all_new_solarisdiskdrives” |
Create a WQL string to identify that event indications to return:
String filterString = “SELECT *
FROM CIM_InstCreation WHERE sourceInstance
ISA Solaris_DiskDrive”;
Set property values in the cimfilter instance to identify the name of the filter, the filter string to select CIM events, and the query language (WQL) to parse the query string.
ci.setProperty(“Name”, new
CIMValue("filter_all_new_solarisdiskdrives”));
ci.setProperty("Query", new CIMValue(filterString));
ci.setProperty("QueryLanguage", new CIMValue("WQL");)
Create an instance of the cimfilter instance called filter and store it in the CIM Object Manager Repository:
CIMObjectPath filter = cc.createInstance(new
CIMObjectPath(), ci);
CIMClass cimfilter = cc.getClass(new CIMObjectPath
(“CIM_IndicationFilter”), true);
//Assuming that the test_a class exists in the namespace
String filterString = "select * from CIM_InstCreation where sourceInstance
isa test_a"
ci.setProperty("query", new CIMValue(filterString));
CIMObjectPath filter = cc.createInstance(newCIMObjectPath(), ci);
