An event handler is an instance of a CIM_IndicationHandler class. You set the properties in an instance of the CIM_IndicationHandler class to uniquely name the handler and identify the UID of its owner. The CIM Event MOF defines a CIM_IndicationHandlerCIMXML class for describing the destination for indications to be delivered to client applications using the HTTP protocol. The Solaris Event MOF extends the CIM_IndicationHandler class by creating the Solaris_JAVAXRMIDelivery class to handle delivery of indications of CIM events to client applications using the RMI protocol. RMI clients must instantiate the Solaris_JAVAXRMIDelivery class to set up an RMI delivery location.
Table 3-7 CIM_IndicationHandler Properties|
Property |
Description |
Required/Optional |
SystemCreationClassName |
The name of the system on which the creation class for the handler resides or to which it applies. | Optional. Completed by the CIM Object Manager. |
SystemName |
The name of the system on which the handler resides or to which it applies. |
Optional. The default value for this key property is the name of the system on which the CIM Object Manager is running. |
CreationClassName |
The class or subclass used to create the handler. |
Optional. The CIM Object Manager assigns the appropriate class name as the default for this key property. |
Name |
The unique name of the handler. |
Optional. The client application must assign a unique name. |
Owner |
The name of the entity that created or maintains this handler. The provider can check this value to determine whether or not to authorize a handler to receive an indication. |
Optional. The default value is the Solaris user name of the user creating the instance. |
// Create an instance of the Solaris_JAVAXRMIDelivery class or get // the appropriate instance of the handler. CIMInstance ci = cc.getIndicationHandler(null); //Create a new instance (delivery) from //the rmidelivery instance. CIMObjectPath delivery = cc.createInstance(new CIMObjectPath(), ci);
