In this example, all the script needs to do is run the add_drv command.
# Postinstallation script for SUNWsst # This does not apply to a client. if [$PKG_INSTALL_ROOT = "/" -o -z $PKG_INSTALL_ROOT]; then SAVEBASE=$BASEDIR BASEDIR=””; export BASEDIR /usr/sbin/add_drv sst STATUS=$? BASEDIR=$SAVEBASE; export BASEDIR if [ $STATUS -eq 0 ] then exit 20 else exit 2 fi else echo "This cannot be installed onto a client." exit 2 fi |
The add_drv command uses the BASEDIR
parameter, so the script has to unset BASEDIR
before running the command, and restore it afterwards.
One of the actions of the add_drv command is to run devlinks, which uses the entry placed in /etc/devlink.tab by the sed class script to create the /dev entries for the driver.
The exit code from the postinstall script is significant. The exit code 20 tells the pkgadd command to tell the user to reboot the system (necessary after installing a driver), and the exit code 2 tells the pkgadd command to tell the user that the installation partially failed.
