Adding a Card Reader (Command Line)
You add a card reader by using the smartcard -c admin
command with the following syntax:
smartcard -c admin -t terminal -j card_terminal_factory_name -x add -d device_pathname -r user_friendly_reader_name -n card_reader_model
-c admin
Indicates that you are viewing or modifying
OCF properties.
-t terminal
Indicates that you are about to configure
a card reader.
Defines the card terminal factory name of the card reader
type. See the specific Card Terminal Factory Name in the procedures below.
-x add
Indicates that you want to add a card reader.
-d device_pathname
Specifies the
device port where you have plugged in the card reader.
Specifies a unique
name for the reader.
-n reader_model_name
Designates the
model name of the card reader. See the specific card reader model name in
Refer to the smartcard(1M) man page for more information.
