Solaris Smartcard Administration Guide
To Add an iButton Reader
  1. Attach the external card reader to the system.
    Physically attach the external smart card reader to the serial port, following instructions in the card reader documentation.
  2. Become superuser on the system where you are attaching the card reader.
  3. Add the iButton reader by typing, for example, the following on one line:
    # smartcard -c admin -t terminal
    -j com.ibutton.oc.terminal.jib.iButtonCardTerminalFactory
    -x add -d /dev/cua/b -r MyButtonReader -n DS1402
    -c admin
    Indicates that you are viewing or modifying OCF properties.
    -t terminal
    Indicates you are configuring a card reader.
    Identifies the card terminal factory name of the iButton reader.
    Be careful to type the card terminal factory name following -j option exactly as shown in the procedure above, with no spaces or returns between characters.
    -x add
    Indicates that you want to add a card reader.
    -d /dev/scmi2c0
    Defines the device port where the card reader is attached.
    -r MyButtonReader
    Specifies a unique name for the iButton reader.
    -n DS1402
    Indicates the model name for the iButton card reader.
  4. Stop ocfserv.
    # pkill ocfserv
    The ocfserv process is restarted the next time you use the Smartcard Console or the smartcard command.
