Solaris Smartcard Administration Guide
To Remove a Card Reader (Console)
  1. Click Card Readers in the Navigation pane.
  2. Select the card reader in the Console pane that you want to remove.
  3. Select Remove Terminal from the Action menu.
  4. Click OK to remove the card reader.
  5. Restart ocfserv, if prompted.
    The ocfserv process is restarted the next time you use the Smartcard Console or execute the smartcard command.
