The following information applies only to applications that support ToolTalk messaging.
Use the action type TT_MSG
to create an action that sends
a ToolTalk message.
ACTION action_name { TYPE TT_MSG … }
The ToolTalk addressing field is always set to TT_PROCEDURE.
The ToolTalk disposition field defaults to the specification in the static message pattern.
The following are not supported by TT_MSG
-type actions:
ToolTalk object-oriented messages
Context arguments in messages
Table 12–3shows the keyword and usage for TT_MSG actions.
Table 12–3 TT_MSG Action Keywords and Usage
Keyword |
Use |
TT_CLASS |
Defines the value of the ToolTalk class message field |
TT_SCOPE |
Defines the value of the ToolTalk scope message field |
TT_OPERATION |
Defines the value of the ToolTalk operation message field |
TT_FILE |
Defines the value of the ToolTalk file message field |
TT_ARGn_MODE |
Defines the value of the ToolTalk mode attribute for the nth message argument |
TT_ARGn_VTYPE |
Defines the value of the ToolTalk vtype attribute of the nth message argument |
TT_ARGn_VALUE |
Defines the value of the nth message argument |
