There are two ways to create a data type definition:
Using the Create Action tool. Using Create Action is covered in Chapter 11, Creating Actions and Data Types Using Create Action.
By manually creating the data type definition.
Creating a data type manually requires you to edit a database file.
This chapter describes how to manually create data type definitions.
For an introduction to data types, see Chapter 10, Introduction to Actions and Data Types .
For reference information about data type definitions, see the dtddsfile(4) man page.
Manually creating a data type lets you use all the capabilities built into the syntax of data type definitions.
You must create an data type manually if you want to use these features of data types:
Location (path)-based data typing
The ability to specify actions associated with the data type other than Open and Print
Multiple name, pattern, or content criteria for the same data type—for example, a data type based on files named *.abc or *.def
Link-based data typing
A data type definition consists of two separate database definitions:
The DATA_ATTRIBUTES
definition.
The DATA_ATTRIBUTES definition
describes the data type's name and the appearance and behavior of files of
this type.
The DATA_CRITERIA definition
describes the typing criteria. Each criteria definition specifies the DATA_ATTRIBUTES definition to which the criteria
apply.
There must be at least one DATA_CRITERIA definition for each DATA_ATTRIBUTES definition; a DATA_ATTRIBUTES definition can have multiple DATA_CRITERIA associated with it.
For example, you could create an attributes definition for PostScript files that described how PostScript files look and behave in File Manager. Then, you could create two separate criteria for the PostScript data type— one based on file name and the other based on file content.
For more information, see Defining the Data Criteria for a Data Type.
This section describes how to create a data type configuration file.
The requirements for configuration files containing data type definitions are:
The files must use the naming convention name.dt
The files must be located on the database search path. The default search path is:
Personal data types—HomeDirectory/.dt/types
System-wide data types—/etc/dt/appconfig/types/language
Built-in data types—/usr/dt/appconfig/types/language. You should not use this directory.
For information on modifying the database search path, see Setting the Value of a Search Path.
Open an existing database file or create a new one.
For more information, see the previous section, Configuration Files for Data Types.
Define the data attributes for the data type using the syntax:
	DATA_ATTRIBUTES data_type_name
 		ICON						image_name
 		DESCRIPTION				string
 		attribute_field
 		attribute_field
where:
data_type_name—a unique name given to this data type.
image_name—file name or path of an icon file. Use the base name for the file. For example, for icon files myimage.m.pm and myimage.t.pm, use myimage.
attribute_field—field that defines the appearance or behavior of the data type.
string—character string. The contents will be the on-item help for the data type.
Define the data criteria for the data type using the syntax:
	DATA_CRITERIA criteria_name
 		DATA_ATTRIBUTES_NAME						data_type_name
 		criteria_field
 		criteria_field
where:
criteria_name—unique name for this criteria definition
data_type_name—name used in the DATA_ATTRIBUTES definition
criteria_field—field used to define the criteria for assigning a file to this data type
Save the database file.
Create the icons for the data type.
For more information, see Specifying the Icon Image Used for a Data Type.
If necessary, create the actions listed in the ACTIONS field of the attributes definition.
Double-click Reload Actions in the Desktop_Tools application group to reload the database.
Suppose your system contains an application named xgif, which displays GIF pictures. Ordinarily, you run the program by executing:
xgif filename
You want to be able to display GIF pictures several ways:
By double-clicking a GIF data file
By selecting the data file and choosing the application from the Selected menu
Open a new file HomeDirectory/.dt/types/GifViewer.dt for editing.
Type the data type definitions:
	DATA_ATTRIBUTES Gif
 		DESCRIPTION				Gif image file.
 		ICON						GifIcon
 		ACTIONS					View
 	DATA_CRITERIA Gif_Criteria
 		DATA_ATTRIBUTES_NAME			Gif
Type the action definition for the GifViewer action:
	ACTION GifViewer
 		EXEC_STRING					xgif %(File)Arg_1"Gif file to view:"
 		WINDOW_TYPE					NO_STDIO
 		DESCRIPTION					Double-click or drop a file to \
 										start the Gif viewer.
Since the definition does not include an ICON field, the action will use the system's default icon.
Type the following map action to connect the GifViewer action to the View action listed in the data type definition. Use the ARG_TYPE field to restrict this view action to Gif-type files.
	ACTION View
 		ARG_TYPE				Gif
 		TYPE					MAP
 		MAP_ACTION			GifViewer
Save the file.
Double-click Reload Actions in the Desktop_Tools application group to reread the database.
defines the appearance and behavior of the data type.  It specifies the name
of the data type, and provides the ability to specify:
The File Manager icon (ICON field)
The double-click behavior and contents of the Selected menu (ACTIONS field)
Use the ICON field to specify the icon used in File Manager. If you do not specify an icon image, File Manager displays only a label.
The value of the ICON field can be:
The base file name is the name of the file containing the icon image, minus the file-name suffixes for size (m and t) and image type (bm and pm). For example, if files are named GameIcon.m.pm and GameIcon.t.pm, use GameIcon.
If you use the base file name, the icon files must be placed in a directory on the icon search path:
Personal icons: HomeDirectory/.dt/icons
System-wide icons: /etc/dt/appconfig/icons/language
An absolute path to the icon file, including the full file name.
You should use the absolute path only if the icon file is not located on the icon search path. For example, if icon file GameIcon.m.pm is placed in the directory /doc/projects, which is not on the icon search path, the value of the ICON field would be /doc/projects/GameIcon.m.pm.
Table 13–1 lists icon sizes you should create and the corresponding file names.
 Size in Pixels  |
 Bitmap Name  |
 Pixmap Name  |
 32 by 32  |
 name.m.bm  |
 name.m.pm  |
 16 by 16  |
 name.t.bm  |
 name.t.pm  |
There are two ways that data types are associated with actions:
The ACTIONS field in the DATA_ATTRIBUTES definition lists the actions
that will appear in File Manager's Selected menu. The first action in the
list is the default (double-click) action.
Actions can be restricted to specified data types using the action definition's ARG_TYPE field.
For example, the following data type definition creates a data type for special “readme” files created by your system administrator that use the naming convention *.rm.
DATA_ATTRIBUTES SysReadmeFile
 	ICON						SysReadMe
 	ACTIONS					Open,Respond
 DATA_CRITERIA SysReadmeFileCriteria
 	NAME_PATTERN						*.rm
 	DATA_ATTRIBUTES_NAME 			SysReadmeFile
A special Respond action is defined below for the file. It opens a writable copy of the file in Text Editor. When the file is saved and Text Editor is exited, the file is mailed to the system administrator (mail address sysadmin@utd).
ACTION Respond
 	ARG_TYPE				SysReadmeFile
 	EXEC_STRING			/bin/sh -c 'cp %Arg_1% $HOME/readme.temp;\
 							chmod +w $HOME/readme.temp;              \
 							dtpad $HOME/readme.temp;                 \
 							cat $HOME/readme.temp |                  \
 							/usr/bin/mailx sysadmin@utd;             \
 							rm $HOME/readme.temp'
If a file is an invisible data type, it never appears in File Manager.
Use the PROPERTIES field in the DATA_ATTRIBUTES definition to specify that
objects of this type be hidden:
PROPERTIES invisible
Table 13–2 shows
the DATA_ATTRIBUTES fields that
are used primarily by application programmers. They specify how files behave
when the user performs various desktop activities.
For more information, see the Common Desktop Environment Programmer's Guide, which is part of the developer environment documentation.
Table 13–2 DATA_ATTRIBUTES Fields and Descriptions|
 Field  |
 Description  |
 For containers such as directories. Specifies an action to be run when a file is moved to a container of this data type.  |
 For containers such as directories. Specifies an action to be run when a file is copied to a container of this data type.  |
 Specifies an action to be run when a file is linked to a file of this data type.  |
 Specifies that files of this data type contain text that can be displayed in a text box.  |
 Specifies the corresponding ToolTalk media type.  |
 Specifies the corresponding MIME type.  |
 Specifies the corresponding X400 type.  |
The DATA_CRITERIA definition defines the criteria used to assign
an object type to a file or directory.
You can use the criteria show in Table 13–3 for object typing.
Table 13–3 DATA_CRITERIA Criteria and Descriptions
You can use more than one criteria for a data type. However, you should not use the NAME_PATTERN and PATH_PATTERN criteria in the same data type.
Use the NAME_PATTERN field to specify the naming requirement. The field value can include the following wildcards:
?—matches any single character
*—matches any sequence of characters (including a null string)
[cc…]—matches any of the characters (c) enclosed in brackets
[c–c]—matches any of the characters in the range c through c
The following data type definition creates a data type based on the file name. The file name must begin with QS and end with .doc.
	DATA_ATTRIBUTES QS_Doc
    DESCRIPTION           This file contains a document for the QS \
                          project.
    ICON                  Word_Doc
    ACTIONS               Open
    DATA_CRITERIA QS_Doc_Criteria
    NAME_PATTERN           QS*.doc
    DATA_ATTRIBUTES_NAME   QS_Doc
The following definition creates a data type for directories named Demo_n where n is 0 through 9.
	DATA_ATTRIBUTES Demo_directory
    DESCRIPTION        This is a directory. Double-click to open it.
    ICON               Demo
    ACTIONS            OpenInPlace,OpenNewView
 DATA_CRITERIA Demo_directory_criteria
    NAME_PATTERN            Demo_[0-9]
    MODE                    d
    DATA_ATTRIBUTES_NAME    Demo_directory
Use the PATH_PATTERN field to specify the path. You can use the same wildcard characters as with NAME_PATTERN.
For example, the following data type uses a criteria based on path.
DATA_ATTRIBUTES Project_Graphics
     DESCRIPTION       Graphics file for the QS project. Double-click the \
                       icon to see the graphic.
 ICON                  QSgraphics
 DATA_CRITERIA Project_Graphics_Criteria
 DATA_ATTRIBUTES_NAME  Project_Graphics
 PATH_PATTERN          */projects/QS/graphics/*
To create a data type based on both file name and location, include the name in the PATH_PATTERN value. You cannot use both NAME_PATTERN and PATH_PATTERN in the same criteria definition.
The QS_Source_Files data type defined below applies to all files named appn.c, where n= 1 through 9, located in subdirectories of */projects/QS.
	DATA_ATTRIBUTES QS_Source_Files
 	DATA_CRITERIA QS_Source_Files_Criteria
 		PATH_PATTERN						*/projects/QS/*/app[1-9].c
 		DATA_ATTRIBUTES_NAME			QS_Source_Files
The following data type applies to all files in the directory /doc/project1 named chnn.xxx where n is 0 through 9, and xxx is any three-character file- name suffix.
	DATA_ATTRIBUTES ChapterFiles
 		DESCRIPTION			Chapter file for the project document.
 		ICON					chapter
 		ACTIONS				Edit,Print
 	DATA_CRITERIA Chapter_Criteria
 		PATH_PATTERN						/doc/project1/ch[0-9][0-9].???
 		DATA_ATTRIBUTES_NAME			ChapterFiles
Use the MODE field to specify the required permissions.
Mode criteria are usually used in combination with name-based, location-based, or content-based data typing. They allow you to limit a data type to a file or directory, or to specify the required read, write, and execute permissions.
The MODE field can include logical operators (Table 13–4) and characters (Table 13–5).
Table 13–4 MODE Field Logical Operators and Descriptions|
 Operator  |
 Description  |
Table 13–5 MODE Field Characters and Descriptions
 Character  |
 Description  |
 The data type applies only to files  |
 The data type applies only to directories  |
 r  |
 The file is readable by any user  |
 The file is writable by any user  |
 The file is executable by any user  |
 The file is a link  |
The default for a particular mode is that the mode does not matter.
The following mode fields restrict the data type as described:
f&!w—read-only files
!w—read-only files and directories
f&x—executable files
f&r&x—files that are both writable and executable
x|!w—files that are executable or read-only
The following data type definition creates an data type for read-only, non-executable files whose file names follow the naming convention *.doc. It assumes that a View action has been defined for the data type.
	DATA_ATTRIBUTES ReadOnlyDocument
 		ICON						read_only
 		DESCRIPTION				This document is not writable. Double- \
 									clicking runs your editor with a \
 									read-only copy of the file.
 		ACTIONS					View
 	DATA_CRITERIA ReadOnlyDocument_Criteria
 		NAME_PATTERN						*.doc
 		MODE									!d&!x&!w
 		DATA_ATTRIBUTES_NAME			ReadOnlyDocument
Use the CONTENT field to specify data typing based on the content of the file. Content-based data typing can be used in combination with name- or location-based data typing.
The typing can be based on either string or numeric content for files. The first byte in the file is numbered 0.
For number content of a file, use the syntax:
CONTENT starting_byte byte number CONTENT starting_byte short number CONTENT starting_byte long number
For the contents of a directory, use the syntax:
CONTENT 0 filename "file_name"
Use standard C notation for octal (leading o) and hexidecimal (leading oX) numbers.
Use of content-based data typing will result in slower system performance. Wherever possible, use name- and location-based typing instead.
For example, the following data type, Writable_Wingz, applies to all files with write permission containing the string WNGZ at the beginning of the file.
	DATA_ATTRIBUTES Writable_Wingz
 	DATA_CRITERIA Writable_Wingz_Criteria
 		CONTENT						0 string WNGZ
 		MODE							w&!d
 		DATA_ATTRIBUTES_NAME	Writable_Wingz
You can create a data type with several independent criteria—that is, the file is assigned to the data type if it meets either (or both) of the criteria.
Create the DATA_ATTRIBUTES
definition for the data type.
Create a DATA_CRITERIA definition
for each criteria.
Use the DATA_ATTRIBUTES_NAME field to connect
each criteria to the same DATA_ATTRIBUTES
definition.
For example, the following definitions create the Mif data type. Typing is based on name or content.
DATA_ATTRIBUTES Mif
 	ICON								Frame
 	ACTION_LIST						Open,Print
 DATA_CRITERIA Mif_Name_Criteria
 	DATA_ATTRIBUTES_NAME				Mif
 	NAME_PATTERN							*.mif
 DATA_CRITERIA Mif_Content_Criteria
 	CONTENT							1 string MIFFile
The search path for data types includes language-dependent locations. The desktop uses the value of LANG to determine the locations searched for data type definitions.
Localized data type definitions must be placed in the proper language-dependent directories along the actions search path.
Personal actions: HomeDirectory/.dt/types
System-wide actions: /etc/dt/appconfig/types/language
Built-in actions: /usr/dt/appconfig/types/language
