Use one of the following syntax conventions:
To create an action that accepts dropped files and issues a command in the form command file 1 file 2 …, use this syntax for the file arguments:
%Args%
To create an action that accepts multiple dropped files, or displays a prompt for a single file when double-clicked, use this syntax for the file arguments:
%Arg_1"prompt"% %Args%
The action will issue the command in the form: command file 1 file 2 ….
This execution string creates an action that executes:
pr file 1 file 2
with multiple file arguments.
EXEC_STRING pr %Args%
