Table 13–2 shows
the DATA_ATTRIBUTES fields that
are used primarily by application programmers. They specify how files behave
when the user performs various desktop activities.
For more information, see the Common Desktop Environment Programmer's Guide, which is part of the developer environment documentation.
Table 13–2 DATA_ATTRIBUTES Fields and Descriptions|
Field |
Description |
For containers such as directories. Specifies an action to be run when a file is moved to a container of this data type. |
For containers such as directories. Specifies an action to be run when a file is copied to a container of this data type. |
Specifies an action to be run when a file is linked to a file of this data type. |
Specifies that files of this data type contain text that can be displayed in a text box. |
Specifies the corresponding ToolTalk media type. |
Specifies the corresponding MIME type. |
Specifies the corresponding X400 type. |
