Use the CONTENT field to specify data typing based on the content of the file. Content-based data typing can be used in combination with name- or location-based data typing.
The typing can be based on either string or numeric content for files. The first byte in the file is numbered 0.
For number content of a file, use the syntax:
CONTENT starting_byte byte number CONTENT starting_byte short number CONTENT starting_byte long number
For the contents of a directory, use the syntax:
CONTENT 0 filename "file_name"
Use standard C notation for octal (leading o) and hexidecimal (leading oX) numbers.
Use of content-based data typing will result in slower system performance. Wherever possible, use name- and location-based typing instead.
For example, the following data type, Writable_Wingz, applies to all files with write permission containing the string WNGZ at the beginning of the file.
DATA_ATTRIBUTES Writable_Wingz
DATA_CRITERIA Writable_Wingz_Criteria
CONTENT 0 string WNGZ
MODE w&!d
DATA_ATTRIBUTES_NAME Writable_Wingz
