You can create a data type with several independent criteria—that is, the file is assigned to the data type if it meets either (or both) of the criteria.
Create the DATA_ATTRIBUTES
definition for the data type.
Create a DATA_CRITERIA definition
for each criteria.
Use the DATA_ATTRIBUTES_NAME field to connect
each criteria to the same DATA_ATTRIBUTES
definition.
For example, the following definitions create the Mif data type. Typing is based on name or content.
DATA_ATTRIBUTES Mif
ICON Frame
ACTION_LIST Open,Print
DATA_CRITERIA Mif_Name_Criteria
DATA_ATTRIBUTES_NAME Mif
NAME_PATTERN *.mif
DATA_CRITERIA Mif_Content_Criteria
CONTENT 1 string MIFFile
